Rancilio Silva brewhead pressure tester and also a q on fast water flow
  • Rancilio Silva brewhead pressure tester and also a q on fast water flow
    Idea 1/ I recently overhauled the trusty v1 Rancilio silvia and i noticed a M6 hex bolt just sitting in the grouphead on the topside and it lead me to believe i could run a valve out if it to a pressure gauge, has anyone done this before to any success or is it a waste of time? I was very curious about what that bolt actually does and why it is there in the first instance.
    Part 2/ i also noticed that the flow rate on the dispense is rather fast, I tried to losen up the OPV to some success, but i still manage to do a 60ml shot in about 18 seconds or so, is this correct, i seem to see people dispense about 30 seconds on youtube, if so what can i do to fix this issue? the reason why idea 1 come to pass is because i have no pressure tester at this stage.
    idea 2/ I want to build some sort of pressure tester if idea 1 is a fail (i know i can buy one from the local coffee shop but that is too easy right) so has anyone had any success making a pressure gauge, being an aussie are there any good shops to buy a good cheap gauge, do they need to be waterproof or will any gauge do it, ie a modded air gauge will it do the trick?
    If anyone has any links i may have missed being new or some images to share or even suppliers for parts Id love the date, many thanks and its good to be on a forum that is local.
    Cheers Jenk
    also i forgot to add, using a VST18gr basket in a naked portafilter and channeling is very minimal (which is great) and try to operate at about 25-30 mins after heating up the machine with the temp surfing for optimum performance.
      Gregpullman has made one that he loans out. There are some pics of his build in this thread https://coffeesnobs.com.au/forum/equ...oad#post871221
        i shall reach out and talk to him cheers barlo
          update, part 2 is solved, i cleaned my grinder out (first time in a while, silly me) and re-calibrated it, so back to brewhead pressure gauge, any ideas forum?
            Get the one in the linked thread
              I mamaged to make a "garage-covid" project LV3Ninja
