miss silvia vs bezzera bz99/bz02 ??
  • miss silvia vs bezzera bz99/bz02 ??
    hi all , can someone explain what is the difference between these machines? why such a price difference?
    Re: miss silvia vs bezzera bz99/bz02 ??
    Hi rudebutt1,
    You are describing two dramatically different machines here.
    The Silvia is a dual purpose single boiler machine - like your machine and the Bezzera is an example of a heat exchanger espresso machine- where you can pull a shot and texture milk simultaneously . A little googling will provide you with further explanation if required...
    regards
      Rudebutt1,
      The may differences are as follow
      Rancilio Silvia
      Single Boiler (300ml)
      Coffee first – change to Steam
      Water tank 3 lt ( not automatic cutout)
      Fill boiler manually
      Bezzera BZ99’S
      Heat Exchange (1.5)
      Can make coffee and Steam at the same time
      Water tank 4 Lt (Automatic cutout when water level is to low)
      Automatic refill for the Boiler level
      Two handles (single and double)
      Feel free to cantact m,e directly fro more information
      Renzo
        ok , thanks for that.
        i think what confused me is the boiler ... many sites describe the bezzera + silvia as having different size boilers , didnt realize that a HX is a boiler with 2 elements etc ...
          hi rudebutt1
          h
          hx machines can have 1, 2, or more elements the bz has 1
          this diagram shows a breakdown of a hx boiler with a e61 group
          http://www.espressotec.com/store/pc/...osyphon_2g.jpg
          this pic shows a silvia boiler disassembled
          hope this helps
          http://sunnypowers.perso.cegetel.net...iler-after.jpg
          graham
            thanks Fix for the diagrams .... that explains it nicely!
            for now will keep on playing with my nemox and mokita (only just got them)
            thank you all for the advice
