grinds
  • grinds
    hi csers,
    i have the problem of getting coffee grinds at the bottom of my cup >. dont think its the fineness of my grind - it happens even at grinds that are too coarse. any ideas? sealing between the portafilter & machine?
    Re: grinds
    Do you wipe out your filter basket before you dose?
    Maybe inconsistent grind of the i-mini?
      Re: grinds
      Also do you flush out group head between shots, have a look and see if you can see any stray grinds up there.
      CB
        Re: grinds
        Maybe your PF is sitting on grinds when you are tamping?? :-/
          Re: grinds
          Unfortunately it could also be that the ground coffee is of inconsistent fineness with both course and extra-fine particles present at all grind levels.
          My Rocky did this before I modified it with plumbers tape, etc., so I would suggest you investigate what options are available on your grinder.
