Why does the head protrude so far....
  • #16
    Re: Why does the head protrude so far....
    Wow! Thanks for all the good advice
    Ill try all your suggestions and see how I go.
    Im still really enjoying the coffees Im getting from the Silvia even if the pucks are a bit sloppy and my dosing and tamping aint quite right yet.
    Its all a learning curve and Im in no hurry. I have no doubt within a few weeks Ill have it all down pat
    • #17
      Good on ya ronk
      Rebuster has the right idea above
      And if you like extra strong coffee you can get a triple basket
      How is the grinding coming along?
      • #18
        Originally posted by Koffee Kosmo link=1217330489/0#16 date=1217385440
        Good on ya ronk
        I had to take the standard 7 gram (?) basket back to the shop because my tamper didnt fit and the nice lady swapped it for a 9 gram (dunno the brand) which fits perfectly and holds exactly the right amount of coffee for a standard sized latte.
        The standard double basket was to big for a single shot (gave me the jitters) and slightly too small for making 2 shots so I havent been using it.
        I may buy a larger double one day, but theres prolly not much point as its usually only me Im making coffee for. My wife drinks instant and only has one cup per day at brekky time.
        Grinding? Well Im learning a lot about the idiosyncrasies of my 0480. The grind can vary a touch depending on the amount of beans in the hopper. Too few and theres no weight on the beans being ground to stabilise the feed.
        It needs to have at least a cuppla inches of beans to give consistent grinds results. The instruction manual mentions this.
        Also fresh beans give a slightly more "damp" grind than beans that have been sitting in the hopper for a day or so and have "dried out" a little.
        A lot of people say theres not enough adjustment on the 0480 but if you look at the way the burr adjustment mechanism works youll see it is a constantly variable threaded design. The position "clicks" just lock it into place at a particular point of the thread. If this is not quite the right spot its easy to go halfway between clicks.
        Close enough is good enough for me anyway
        • #19
          To help with jumping beans in the hopper
          Fill a balloon with rice or coffee beans to the appropriate size for your hopper tie it off
          Place that on top of the beans while grinding
          It provides enough weight and stops beans from jumping
          Remember grind should be about the size of table salt as a start point
          • #20
            OK, using the single basket is difficult nigh impossible with the standard 7g basket, (probably very difficult with a 9g) on a Silvia, so much so that most of us dont bother.
            It is easier to dose and tamp the double basket, and then......
            you can either;
            - cut your pour shorter, ristretto style, should give a richer sweeter shot, which doesnt necessarily have more caffeine, as caffeine content is related to the length of brewing, or pour time, or,
            - using the double spout, only catch from one side, and let the other side pour into the drip tray.
            Then you should have less trouble with the soggy pucks.
            Regarding the bolt head, I use a round bead screw (not countersunk) looks much nicer, and does the job fine. If you clean your shower screen regularly, as you should, and only tighten the screw up finger tight it will never get stuck.
            Bullitt
            • #21
              Thats a great idea!! I learn somethin new each time I come here
              I did a comparison about 15 mins ago. Ive been grinding too fine and I actually stalled the machine this morning. Ive gone up a cuppla clicks, its on the low side of 13 now. The shot I just poured was pretty good, but still have soggy pucks.
              you can either;
              I get a lot more water through the double basket so I reckon Id need to cut it short at about 15 - 20 seconds.
              Bullitt
              Yeah I took mine out last night. It wasnt very tight and I only did it up gently when I screwed it back in.
              Heading into town soon so Ill see if I can match it up at the local bolt shop
              • #22
                Hi
                If you stick with the hex head one you will be able to remove the showerscreen and clean under it easier. Just do it up finger tight as others say. The bolt is not the problem causing soggy pucks.
                Mike
                • #23
                  Originally posted by speleomike link=1217330489/20#21 date=1217407018
                  Hi
                  I changed it to a lower profile dome head screw today. Its stainless steel and uses a philips head screwdriver. I have a nice short one which makes removal super easy.
                  Mike
                  Yes I know
                  • #24
                    Got an even lower profile stainless screw yesterday and have been monitoring my pucks by loading, tamping then carefully removing the loaded basket and holding it up to the group head seal, then inspecting it.
                    No more fractured pucks like I was getting with the standard harbour bridge bolt.
                    My pours are consistent and Im getting a much nicer crema so I figure maybe the fractured pucks were screwing things up a bit.
                    Got my soggy puck issue sorted out now too.
                    • #25
                      [smiley=tekst-toppie.gif]
                      We like happy people that enjoy the ride
                      • #26
                        Excellent news g62.... [smiley=thumbsup.gif]
                        Now, the journey can really begin 8-) [smiley=laugh.gif],
