Where to buy replacement Sunbeam tubing
  • Where to buy replacement Sunbeam tubing
    I have a EM6910 and, in trying to replace the steam pump, have decided to replace the tubing too. (this was not my desire, but the old tubing is so vulcanised I cannot get the tube over the steam pump fitting without splitting it). Where can I get some appropriate tubing - it's 5mm ID, but presumably needs to cope with some heat/pressure.
    James
    G'day James...
    Pretty sure it will be something like the stuff in the link below, from JetBlack Espresso...
    https://www.jetblackespresso.com.au/...on-pipe-6x4mm/
    P.S.
    You will need to heat the end being attached to the pump, etc using boiling water to soften the tubing a little.
      Thanks, Mal!
