Wrong Silvia v2 steam adapter
  • Wrong Silvia v2 steam adapter
    I've been fixing up an early v2 Silvia, and was looking at replacing the swivelling steam wand. I have a few ball joint steam wands lying around from some em6900, which seems to use 3/8 BSP threads, so I though ordering a Silvia steam adapter fitting on Ebay which is advertised as fitting the v1/v2
    But it doesn't fit. It looks like an M8 thread, but the threads on my machine looks to be 1/16 BSP. Does anyone know the exact fitting sizes on the early v2?
    Click image for larger version  Name:	PXL_20221013_012117139.jpg Views:	0 Size:	240.5 ** ID:	930890 Click image for larger version  Name:	PXL_20221013_012038752.jpg Views:	0 Size:	302.6 ** ID:	930891 Click image for larger version  Name:	PXL_20221013_012027067.jpg Views:	0 Size:	292.4 ** ID:	930892
    From the looks of it, I could possibly also use a female - male 1/4 BSP to 3/8 BSP fitting, which I believe are the thread sizes for the swivelling and ball joint steam wands respectively?
    Edit: in the first picture, new adapter from Ebay at the top, the adapter currently used with the swivelling steam wand at the bottom. Last picture: the adapter does't go into the steam valve at all.
    Edit: my BSP sizes might be completely off.
    Solved it by getting a 1/4 BSP to 3/8 BSP adapter at bunnings. It's a bit too long and it doesn't have the sealing flange of the other adapter, but it will at least work ok until I get a bit shorter adapter ordered through aliexpress (though still without a sealing flange).
    Click image for larger version  Name:	1c1b219e-3278-46f7-bd1c-8243a370d7c4.png Views:	1 Size:	680.8 ** ID:	930943 Click image for larger version  Name:	PXL_20221014_025453791.jpg Views:	1 Size:	237.5 ** ID:	930942 Click image for larger version  Name:	Brass-Adapter-Fitting-BSP-Reducing-Hexagon-Bush-Bushing-Male-to-Female-Connector-Fuel-Water-Gas-Oil.jpg_640x640.webp Views:	1 Size:	39.2 ** ID:	930941
    Edit: this is with the existing adapter in place that held the old steam wand.
    • WhatEverBeansNecessary
      WhatEverBeansNecessary commented
      Editing a comment
      Will a little teflon tape help? The good stuff will be usable in the steam temp range.
    No the thread was all wrong. M8. Tested it with a thread tester. The existing steam adapter for the old wand had 1/16 BSP threads. I wonder if the V1 Silvia might have used M8 threads, but I can't find any information on it.
