EM7000 blowing steam pipes
  • SteveDB
    Hi Hedge.
    Do you hear the two relays clicking when the machine is sitting idle?
    It could be that the steam relay has stuck on, ie. the relay contacts have welded together, and the steam boiler is overheating.
    I have replace the relays about three times now. I replaced them with RS Components part #719-6341.
    Steve
  • Hedge
    started a topic EM7000 blowing steam pipes
    Hi there. I have a E7000 which has started blowing the Teflon steam wand pipe. I’ve had 3 blow in the past 6 months. I suspect the steam pump may be over pressurising, however I’m not sure. Just wondering if anyone else has experienced the same problem, and whether you may have found a solution? Thanks in advance.
