My VBM Piccolo has started retaining a little pressure after brewing a shot and not fully purging once the lever is down. I've backflushed it with cleaner but this hasn't helped. However, the valve is not dripping at all. Does this mean I need to buy a kit to service the entire E61 grouphead?
Vibiemme Piccolo's E-61 not fully purging
To answer your Q = Yes and No.
State the obvious the Brew Chamber is witholding pressure upon you 'releasing' the super lever.
Valve / Seals Sticking - possibly. Easy to dis-assemble, check, lube etc.
Check the lower exhaust valve as first port of call.
Possibly wear to the cam / valve rod (some like Rocket, VBM ?, have a threaded pushrod as a replaceable component) as part of the valve / pushrod assy. These or the Cam face may be worn therefore not delivering the 'full stroke' of the valve and therefore 'releasing' brew group pressure.
Report back your findings to assist others in future.
