Analysing naked portafilter shots
  • redzone121
    Re: Analysing naked portafilter shots
    My 2 cents worth. I personally love the visual on the Naked PF. I dont tend to get stripping from SOs but mostly from Blends. I wouldnt think the lighter color on the stripping early on in the shot would be bitter. I certainly have not tasted it to be so in my limited experience and the transformation later in the shot to what I would call true blonding is where the caffeine bitterness gets nasty. Anyway while the visual stuff is cool to watch and does give you valuable information dont forget its all about taste
    CB
  • roknee
    from the home barista article
    dan kehn: "Tiger striping and mottling are leading visual indicators of a good extraction. Tiger striping is formed by the contrast of darker and lighter crema in the espresso stream; ideally it begins early in the pour and is sustained through the end. Mottling is the in-cup confirmation of a good extraction; it is the darker brown speckling and reddish-brown splotches formed on the surface of the crema.
    Under-extraction occurs when too few coffee solids are extracted, resulting in a weak, dull flavor. The visual signs are a rapid, high-volume extraction having a uniformly light blond crema."
  • garglebutt
    Originally posted by 2D0118300F170512600 link=1231241066/2#2 date=1231940720
    Im totally against tiger striping. To me it shows the shot is channeling or many other problems.
    Im afraid I have to disagree with you. If SO beans were entirely uniform in size and density throughout, and the roasting process treated each bean exactly the same, you might stand a chance of having homogeneous colouring but in reality the variation in bean and roasting can be expected to produce variation in the extraction even from well ground coffee.
    A point worth mentioning is that tiger striping is far more obvious with a naked portafilter because the stream is not being blended as it passes through a spout.
    The key thing to avoid is blonding which makes the extraction thin and bitter.
  • flynnaus
    Isnt the white part of the pour/tiger striping forming the crema?
  • fringe_dweller
    I guess it would depend whether your shot is a blend or a SO. For a blend Id expect different colours, and hence tiger striping.
    Grant
  • MaxPower
    I have to disagree with that article.
    Im totally against tiger striping. To me it shows the shot is channeling or many other problems. If you taste the white tiger stripes and the dark tiger stripes, Im sure you will find the while stripes bitter and the dark stripes full of flavor. The photo given looks under extracted giving off Tiger stripes.
    It actually says in the article to avoid the blond coffee extraction (under extraction), yet gives permission to it in the photo and in the "tiger striping" comment. Interesting.....
    Therefor I suggest you go for an even color and get as much dark and rich coffee from the shot as possible.
    If you can extract an even color, it shows the shot is moving evenly through the PF (fully extracting). It also allows you to see the where you are channeling and allows you to compensate on your next shot.
    Always check your biscuit, it will tell you all you need to know if you know what to look for. (dose, tamp, even pressure etc)
    Go for a grind that allows those 3 drips in around 7 secs, 2 drips in around 15 secs and by the time the 2 drips join you should notice the color lightning signaling the end of the shot around 24 secs.
  • roknee
    hey buschy
    heres an article from home barista that you may find helpful
    http://www.home-barista.com/naked-extraction.html
    aaron
  • Buschy
    started a topic Analysing naked portafilter shots
    Ive been using a naked portafilter for about 10 days now. Its interesting watching what happens under the filter basket. Typically the extraction starts out dark and thin around the perimeter, then the circle narrows and lightens in colour as it heads towards the centre. Most of the time once it reaches the centre I end up with a thick single stream which consists of a mixture of light and dark espresso but sometimes there are 2 or 3 streams for a brief moment before they join. I assume the first scenario is what youre aiming for?  :-?. Can anyone provide a bit more info on what should happen if you have dosed and tamped correctly, and recommend a good source with additional information and photos?
    Is it just me or do you find you end up with more crema?
