Ive read on CS that HX machines shouldnt be regularly backflushed with descaling solution (although i was told by the salesperson to do it weekly..?)
But do I really need to go to the expense of installing a water filtration unit under my bench???
My local supplier states water hardness is very low,at about 42 mg/L (CaCO3).. (can post more detailed info if required).
Cheers!
Cheers!
I used to live in Perth and found the water shithouse. To vary degrees depending on location, bore water is mixed with dam water to stretch it out a bit. Those mission brown stains over brickwork where bore water is used will tell you how many dissolved solids are present - heaps!
...thanks so much for sharing the knowledge.
