Im with you slow, I disagree with what I said as well
Its definatly easier to use a mallet. I think the machine Bruce got was in much worse condition, hence where he says:
You should see the (remains of) the steel spring clip. If the clip should still be intact you will need to
use some kind of a tool (awl or special pliers) to remove it.
