Machine Upgrade from Sunbeam EM6900
  • Machine Upgrade from Sunbeam EM6900
    Gday everyone,
    I am interested in feedback or suggestions of what coffee machines I should consider advancing to from my Sunbeam EM6900.
    It is for home use only so do not need to pay thousands... Would appreciate all suggestions.
    Many Thx Starky
    Re: Machine Upgrade from Sunbeam EM6900
    there are plenty of upgrade options.
    questions youd need to answer before anyone can give you meaningful options might be:
    - Do you have a budget limit in mind?
    - Is there anything in particular that you want from your new machine?
    - What type of drinks do you make?  How many, how often?
    The most logical upgrade (IMO) would be the soon-to-be-released Breville dual boiler.  But there are other many options priced above and below that as well.  A visit to a CS sponsor is always recommended
      If you dont plan to spend thousands, dont upgrade.
      What you can do is get a top notch grinder instead. It will make a big difference to your quality an consistancy of shot. I bought a Mini Mazzer for my 6910 and it took the machine to a whole new level.
        JayBee. Wow. I am interested in learning more. What specifically did you experience? Better flavour? Fuller flavour? Smoother shots?
          All of the above. But most importantly for me, I can get absolutely the same result every time (especially given that I weigh the beans rather than rely on the doser).
          My 4080 was a step up for me originally, but I found as it wore out, I wasnt getting great results in the cup nearly as often as the grind subtly altered between shots due I expect to larger tollerances in the grinder. The arrival of my MM has ensured that the grind variable is tamed, and when it wears out, I can get parts easilly and cheaply making it a great long term investment.
          And when you do put in those extra $$$ for s mega machine, you will already have the grinder for it!
