Re: Pressure and flow
This is exactly why i used our VST baskets when showing you the silvia, not the synesso basket that came with it. when we were using synesso baskets we were roughly a quarter turn coarser on the roburs. we had to tighten the grind up considerably when we switched to VST. Also i can confirm that a hotter temperature with all other variables the same will result in a faster flow rate.
ill hold up the two baskets to the light when im at work next and come back with results.
