Guide to Using an Rancillio Silvia
  • #16
    Re: Guide to Using an Rancillio Silvia
    Jim
    I recall seeing a post by yourself on another forum where you felt the group ran to cool with the 100c thermostat compared to the older thermostat, have you done any more research on this?
    • #17
      A year or so ago, I performed similar testing on a different V2 Silvia. On that first machine, the group ran several degrees cooler than the current machine. On the first machine, I never pulled a shot that I thought was hot enough (they were running around 90C-91C).
      But on the current machine, I was able to pull shots through the Scace device at around 92C-93C, which is within an acceptable range.
      With both series of tests, I used accurately calibrated logging equipment (in fact, it is the same equipment). So the only explanation I can offer is that there must be a fair amount of variation between stock thermostats.
      Jim
