I was just about to fit a PID to my classic but when I opened it up I found it has a small leak on the pump outlet. It is between the plastic outlet and the brass elbow, I am thinking of removing the elbow and putting some ptfe tape to try and stop the leak. Is this a good way to go?
Gaggia Classic pump leak
Re: Gaggia Classic pump leak
Gday David,Originally posted by dkelly60 link=1159589342/0#0 date=1159589342I was just about to fit a PID to my classic but when I opened it up I found it has a small leak on the pump outlet. It is between the plastic outlet and the brass elbow, I am thinking of removing the elbow and putting some ptfe tape to try and stop the leak. Is this a good way to go?
Is it possible to observe the location of where you suspect the leak originates while the pump is running (being very careful about the exposed 240V AC connections)? If the water is actually leaking from out of this join, then removing, cleaning and replacing the Teflon tape will probably fix it for you. If its a crack in the plastic pump housing though, then a new pump will be required unfortunately. All the best,
The pump can provide up to 15bar pressure. If there is a leak in the pump plastic output tube, then wraping in teflon tape will be like trying to hold back a tsunami with a salami... If however, the leak is from the thread where the elbow screws in, then teflon tape may well work fine and you can eat the salami. New pumps are about $50, so no drama if it needs replacing. Besides, after getting the PID gear all sorted, a pump is just a minor set back.
This is basically what Mal said, but with the addition of a salami.
Good luck.
Mark.
LOL ;D,Originally posted by Sparky link=1159589342/0#3 date=1159844489If there is a leak in the pump plastic output tube, then wraping in teflon tape will be like trying to hold back a tsunami with a salami...
Good one Mark.... Just trying to picture you waving a slice of salami (my preference is for Hungarian) at an oncoming Tsunami :P,
Maybe if you got a really big salami and used it as a personal floatation device? That way youd also have several days supply of food with you after the tsunami dropped you off. ;DOriginally posted by Mal link=1159589342/0#4 date=1159849055Good one Mark.... Just trying to picture you waving a slice of salami (my preference is for Hungarian) at an oncoming Tsunami :P,
Java "How long will a salami float?" phileToys! I must have new toys!!!
