Hi All,
I hope someone can give me some advice.
heres the symptoms; Over the last week or so Ive been noticing the extraction from the grouphead has been a bit slow and "dribbly". I thought it was the grind I was using so have tried different grind / tamp combos to no avail. This morning the pressure from the grouphead appeared to be very low and now no water is coming through at all !
The steam and hot water work fine (plenty of heat and pressure) the grouphead heats up etc but nobody home! could this be the pump? although I can hear something going on and would I get the hot water / steam / normal horrible pump noise if I had a faulty pump?
Any thoughts would be appreciated or alternatively the name of a reputable repair agent or should I send Miss Silvia to the great espresso lounge in the sky?
cheers
cheers
