Caffettiera stove top espresso
  • hazbean
    Re: Caffettiera stove top espresso
    That stumptown method looks very interesting. We had been using one
    for camping for years (took the Mondiale once, but dont often get away with it ). Had evolved a technique of heating slowly and removing
    soon after first "gurgle", then allowing flow to finish. But this still
    gave a "burnt" taste, so switched to plunger.
    Will try this method to see how much it reduces that effect.
  • luca
    Matt, youre in luck; there are currently two threads on the topic:
    http://coffeesnobs.com.au/YaBB.pl?num=1174971088/3#3
    http://coffeesnobs.com.au/YaBB.pl?num=1175047754/7#7
    Also, make sure to check out the brewing guides at stumptown.
    A caffettiera will not make espresso, but you can get a rich, concentrated brew that actually expresses the nuances of the beans that you are using. Screw up, though, and you get an ashtray!
    Luca
  • mattm
    started a topic Caffettiera stove top espresso
    Bean a while since my last post started studying again after a long break.
    Just brought a stove top espresso machine to take camping ( wife refuses to let me take silvia with us) and would like some advice on using it.
    Any suggestions for grind settings I have a rocky and silvia should i use a grind setting similar to that which i use for the silvia?
    There were no instructions supplied with the unit so unsure of how to use it but probably will work it out.
    Any help much appreciated
    mattm
