Espresso machine?
  • Espresso machine?
    VERY CHEAP!
    Cost me $48 on slEEEze bay, It weighs just under a kg, [with a loaded PF!].....................about 1/16th a Silvia.
    [except that the silvia makes brew about 16,000 X better]
    sorry to OT the thread, Ill go away now, but for your viewing pleasure..
    Re: Breville BarAroma grinder
    Looks nasty!
    You should see the Aldi Espresso Machine.. absolute shocker and makes horrible coffee...
      Re: worst Espresso machine?
      the Aldi doesnt have the following features:
      Instead of a three way valve, its got an exploding portafilter.
      If you look even more closely, you might see the corrosion inside the PF...this used to appear overnight accompanied by some crystals that looked like battery acid.
      It was around this time the upgradeitis kicked in.
      Challenge..... what is the worst machine out there?
        Re: Espresso machine?
        Ah, this one has a pretty bad reputation...Black & Decker HCC70 Home Cafe Pod Coffee Maker
          The Phillips Senseo comes pretty high on my list of shockers....
            I reckon that that "Coffee Cassette" is going to be up there...
              I had a $90 el cheapo from Target years ago. I think I made about 3 coffees in it. If you like your coffee burnt it was excellent. Cant remember the brand though.
