Cold brew
  • Cold brew
    Ive been reading about cold brew coffee makers (specifically the Toddy: http://www.toddycafe.com/shop/product.php?productId=67) and Im curious to know if anyone here has had any experience with cold brewed coffee? Ive seen a couple of articles around the place touting the wonders of it, and I would really like to know if its as good as claimed.
    The second question I have I guess would be does anyone know of any Australian distributors for cold brew systems (the Toddy, or anything else)?
    Re: Cold brew
    You could try a search in CS using the term cold press. Javaphile is a big enthusiast of cold press coffee and has posted some long responses to the same question in the past.
    Matt
      Re: Cold brew
      http://coffeesnobs.com.au/YaBB.pl?num=1136514307
      http://coffeesnobs.com.au/YaBB.pl?num=1122540128
      I do it occasionally. Its great if you need a coffee flavour in a dish you are cooking but dont want the bitterness that a cooled down espresso has. Granita, jelly, custard, tiramisu, cold alcoholic cocktails...
      Add some agar (or gelatine) to the CP solution and then foam it up with an cream whipper such as iSi.
      http://www.isinorthamerica.com/
      One does need a good amount of coffee for cold press brewing.
      re: equipment
      I just brew in a glass jar for 24 hours and then filter using a swissgold 1 cup drip filter (KF300). Bodum have a similar drip filter available.
      http://www.amazon.com/swissgold®-300-One-Cup-Coffee-Filter/dp/B000G71J6G
        Re: Cold brew
        Thanks much for the thread links/info!
        Sorry about reposting the question, I did actually do some searching but in my brilliance I didnt change the Post was made in the last... away from week.
          Re: Cold brew
          No worries! I actually like it when previously discussed topics are reborn. Theres always something new to learn. No dumb questions here.
            Re: Cold brew
            Hhhhmmmmm......CP! How do I love thee, let me count the ways...!
            Because the search results are limited on here use google or your favorite search engine to look for CP or "cold process" with the added command of site:coffeesnobs.com.au to limit your results to just this site.
            Java "CP is wonderful stuff!" phile
            Toys! I must have new toys!!!
              Re: Cold brew
              Ive done a fair bit of CP brewing since I found out about it - great stuff, very useful.
                Re: Cold brew
                Are Toddys avail. in Aust?
                  Re: Cold brew
                  If not, maybe you could use a french press to start the process, then pass it through lots of filter paper?
