Sunbeam EM6910, is mine haunted?
  • Sunbeam EM6910, is mine haunted?
    Around midnight last night I began hearing a sound which I at first thought was distant doof-doof music (esp being Saturday night  ) but on closer investigation discovered it originated from my Sunbeam coffee machine in the kitchen ...... which was turned off
    It was a slow rythmic beat, not loud at all, but in a quiet house definately could hear it from the next room. Best way to describe it is  the quiet pumping of a fish tank pump but much slower beats.
    I turned off the powerpoint at the wall and the sound stopped.
    Anybody else had their Sunbeam do the same thing? Normal or is mine haunted?
    Re: Sunbeam EM6910, is mine haunted?
    Not normal. Youve got an internal leak which is shorting on the main board and switching on the pump. (You may also smell a burning electrical smell).
    I dont want to alarm you, but you need to unplug it, stop using it and get it back to the service centre as soon as possible .
    This happened to mine - and in fact is back in for repairs after a second recurrance.
      It would appear with Sunbeams when they are turned off unless you turn them off at the wall they are still alive. I have not experienced the noises you have mentioned but would err on the side of caution and get it checked out. :-/
        This have been covered in a number of other posts..
        1: Does happen
        2: Sometimes a leak problem
        3: Other times unknown.
        Solution do not leave in STANDBY Mode... The EM6910 heats up quick enough that you should turn it OFF.
        This is also a power saving approach as nothing in standby mode is clean... They all dray some power. Thus Turn it off, your not putting the system at risk and your saving a few cents..
        We turn most things off at night at the wall and when going away (even for a few days) all power points = OFF and the Gas as well.
        In a near 100 year old wooden home - Any fire will do us in... Not worth the chance. Clocks are Battery operated and thus the clocks on the TV / VCR and Microwave etc are not required.
          Is my coffee machine haunted?
          Thanks for the replies. So looks likes its nothing as exciting as a haunting ;-)
          It hasnt made the sound since and there was no associated electrical smell, so not sure if I should bother taking it in (and drinking instant till I get it back
          Interested to hear that even with the machine turned off (no lights on) that the unit is still in a standby mode. I didnt see anything in the manual about that, might have another look.
            If it is a leak and you ignore it, itll start corroding inside. Id take it in for a check if I were you...
