So what was bought? I'm tryiing to work out the best option now before my machne arrives in a week or so. Something that doesn't require a plumber would be best as I'm country.
HX Water - Perth
Rainwater is very acidic, usually around 5.5 which is not good for coffee machines. You can easily test it with a $10 test kit from bunnings.Originally posted by Burnsy View PostDoes anyone in Perth use rainwater? I am using a tank for my new machine and have access to clean rainwater so had planned on using that, any issues?
This is what I'm using... if you can be bothered. I use Pureau water which is stocked by Woolies and Coles in 10 litres casks.Originally posted by kexkez View PostSo what was bought? I'm tryiing to work out the best option now before my machne arrives in a week or so. Something that doesn't require a plumber would be best as I'm country.
https://s3-ap-southeast-2.amazonaws....ter_recipe.pdf
so this has to be tweaked to be used. its not ok as is? I'm looking for something that doesnt need tweaking if possible.Originally posted by flashpixx View PostThis is what I'm using... if you can be bothered. I use Pureau water which is stocked by Woolies and Coles in 10 litres casks.
First crack or nothing
- Nov 13
- 3438
- Sydney (West)
- Filter or long black: clean with crisp acidity
- Send PM
The easiest way to tweak water that had too low TDS is to add some tap water to it too bring the TDS up to a desired level. If your water is as hard as you think it won't need to be much.
