I know about the Scottie Callaghan dosing tools and for now an old credit card with two different arcs cut on the long sides is meeting my needs. But I have a question about bean dose, not grind dose. I have a doserless Rocky and dont want any beans left in the grinder after I make my shot. Im using a plastic measuring scoop to get the right amount of coffee into Rocky, but a few beans more or a few beans less can make a big difference to the final dose. How are others dealing with the issue of getting the exact same amount of beans into your grinder for each shot? Is there something like the Scottie C kit but for bean quantity rather than final grind level?
Any tips for dose quantity gadgets?
Re: Any tips for dose quantity gadgets?
SeanSheep... nice scale! Do you mind sharing the brand?
Something weird happened with mine today or my cleaning technique changed a bit... I usually get ~0.5g less than what I put in... I ended up with more than I put in!
I dont want to breach any posting guidelines, so mods if this is too much then i apologise and feel free to delete.
If you go to the site in question these are the product numbers, which are searchable:
17486 300g/0.01g Black
17481 300g/0.01g Silver
17485 200g/0.01g Black
17480 200g/0.01g Silver
Mine is actually the 200g/0.01g Black model (not 300g).
Its not very often that I get to pull only one shot in a session but on those occasions that I do, I just use a standard 1 Tablespoon Measure x 2. Just strike the beans level with the rim and dump into the grinder. About 19g +1.0/-0.0 whole beans go in...Originally posted by 514A404B425147424F424142230 link=1297899281/0#0 date=1297899281How are others dealing with the issue of getting the exact same amount of beans into your grinder for each shot?
After first pulsing the grinder a couple of times (to remove any old grinds, about 1.0g) then grinding properly and sweeping out the grind chute, I end up with about 18g +1.0/-0.0 of fresh coffee grounds. After dosing , I end up with either a perfectly level dose in the filter basket or a very slight mound that gets swept off.
Makes a perfect shot every time (even if I do say so myself)....
8-) and no need for digital scales or any other device.
Nice! What kind of resolution do you have?Originally posted by 6E524F545E5F485D555E3A0 link=1297899281/10#10 date=1297926168I use the palm of my hand to feel the level in a spare basket that is now only used for measuring beans to go into the hopper.
Ive checked the accuracy of my hand using digital scales and its consistent.
How often do you recalibrate your hand?Originally posted by 003C213A303126333B30540 link=1297899281/10#10 date=1297926168Ive checked the accuracy of my hand using digital scales and its consistent.
Only 1g.Originally posted by 76796170616461000 link=1297899281/11#11 date=1297928677Nice! What kind of resolution do you have?
Not often enough for you so Ill try get around to it tomorrow.Originally posted by 59656C7461000 link=1297899281/12#12 date=1297929850How often do you recalibrate your hand?
How do you account for the uneven grind that gets produced when there is no wait settling the beans onto the burrs?
I have seen some people use their tamper as a weight, is this what you do?
