Should i buy a lever or PID my Silvia??
  • #46
    Re: Should i buy a lever or PID my Silvia??
    Hi Wynton87
    So should you buy a lever or PID your Silvia?
    Its nice that you have had quite a lot of advice above. Ill throw in my 2c worth.
    First off ... I PIDd my Silvia many years ago, I also have a LaPavoni Europiccolo Lever machine & a PontVecchio Lusso dual lever machine so I can talk from experience with all three.
    My first machine was a Silvia and I PIDd it with the PID kit that you can buy. It was about $700 many year ago but came with the PID unit, all the wires, fittings, mounting and instructions. Even though I have designed PID gear in the past getting it all as one kit saved me lots of time and effort. (PS. You cant get good a PID unit for <$50). After this I didnt have to "temperature surf" and I could just come up to the Silvia and make a cup fast with no frigging around. I could also experiment with slightly different temperature settings for fun. But it does not make better coffee compared to spending time on the Silvia to get it right. It can help you make good coffee more consistently. I sold the PID Silvia to a CSer many years ago. It is a nice machine with PID.
    Levers ... LaPavoni and the PonteVecchio Lusso have small portafilters and baskets (48mm dia) and you will really notice that coming from a Silvia. You wont get as big a shot.
    The LaPavoni, as people have mentioned, will give you one or two shots, then you will need to cool it or leave it. By then you will have run out of water in its small boiler and you will have to leave it to cool before filling up.
    But if you practice and are lucky those LaPavoni shots can be really luscious. Its a machine "just for you".
    The PonteVecchio is nice as it has two levers and it does not over heat, you can leave it on all day. Its got a big boiler so you can do several shots at least. I can do a nice shot for myself and my wife but for her I do a machiatto and there is not enough coffee in the shot for a full sized cup. It makes quite good espresso, again like all lever machine after a bit of practice.
    What would I really like? A lever machine with a 58 mm portafilter!
    Summary for you. A PID is not needed to make a better shot - it will make it easier to use the Silvia and will add techno-bling. A lever wont make nice big cappuccinos for guests but it will be fun to play with. It gives real coffee-cred. They are apples and oranges. Of course this probably hasnt helped you make the decision :-)
    Mike
    • #47
      Actually Mike I think youve brought in the little bit of extra info needed & tidied it all up nicely. Good post
      • #48
        Originally posted by 2A293C353C363430323C590 link=1338355533/45#45 date=1339418158
        This is a true statement .. but only because "good" is a relative term.
        An industrial control technician , or military procurements agent, might well argue that you cant get a "good" PID for under $2000, .
        ..It all depends on the application requirements and specification you require.
        To control the temp on a Silvia, you dont need a very sophisticated PID, infact you dont really need a PID at all...a simple $10 digital thermostat will do the job very nicely within 1 -2 degrees, but i have yet to find one with the same small form factor as the miniature PIDs.
        So whilst a $20 PID may not be "good" for controlling industrial equipment, it is infact grossly over spec for keeping the Silvia boiler at any temp you may wish to set, and give you a visual temperature display as a bonus.
        Its certainly a much better piece of control equipment than the stock thermostat !
        • #49
          "Its black"
          "No its not, its white"
          "Black"
          "White"
          Repeat ad infinitum :
          • #50
            Originally posted by 596D7A6C77405C7079797A7A1F0 link=1338355533/35#35 date=1339380047
            Cutting back to the chase. The answer to the question is, decide what you want.
            Sorry fresh coffee that doesnt really help..  :-?
            But i really liked speleomikes comments about his exprerience with both a pidd silvia and his pvl now, im pretty interested in the pvl now. I hate to bang on but speleomike, but could you answer me this, given the same bean/circumstances ect, will your pvl make a better ristretto than your old pidd silvia?? thanks
            • #51
              comparing my pidd gaggia classic and my pvl, yes, the pvl produces a noticeably superior ristretto.
              • #52
                Yes but thats just an individual opinion of what is "better".
                The two machines make different coffee, period. Both ristrettos can be great but different, and then an individual has to make a choice between the two.
                Wynton, you need to go somewhere where you can compare the two machines (and forget the PID which is only a complication in a choice between two different machines.....compare Silvia to PVL...same beans, same grinder same operator (who needs to know how to use both to best effect)). That is the only way you are going to be able to make a decision for yourself.
                Its not just the difference in the coffees each will produce, there is also a whole different modus operandi involved.
                Which is better, an orange or a mandarin?
                I will say again...you will need to make the choice for yourself. Asking others what they think is "better" doesnt get you what you want only what someone else thought.
                • #53
                  Originally posted by 152136203B0C103C35353636530 link=1338355533/51#51 date=1339836547
                  Depends on the warranty.
                  • #54
                    As per Attilos post above.
                    Coffee can be different not worse or bad but just different with a range of gear.
                    I did some testing a little while ago with a K8 (84mm flat burr) and a K10 (68mm conical) set them both up to run similar shot times on the same dose and yep they were different. To taste the k10 by fraction but I wouldnt have been upset by th K8 shots.
                    Also ran a few back to back tests ( I want to do more of this) 55mm Izzo against the 58mm Fioranzato Levers. 55mm Izzo is better than the 58mm across the board (so far), the 58 is never a bad shot but there is a little something extra in the 55mm.
                    I suppose the point here is get the best out of whatever gear you have with good technique will kick the ass of a numpty at your local cafe on their YAWN : Synesso/Robur or LSM or ....... if the dont care or dont take the time to get it right.
