Descaler. Which one?
  • Descaler. Which one?
    I have a Silvia that is coming up for a descale. Just wondering what descaler is recommended for it?
    There are so many different types Im not sure what type or brand to get. Any suggestions would be great!
    Cheers, Jai
    Re: Descaler. Which one?
    i would recommend the clean machine triple action descaling solution.
    Its a great product and good value for money.
    I use it for my Giotto
    Mal
      Cheers, Jai
      Hi. I was at Sam's Warehouse yesterday where I noticed a new line of British made household cleaners under the Astonish brand name. One of the products is a descaler that comes in a 750ml bottle, which cost only $2! There is no smell at all, and the label said to use 100ml for domestic coffee machines. The products were on a lone stand in the centre isle.
        Get one designed specifically for coffee machines!! The machines are too expensive to save a $ or 2 and risk damage.
        Many of the sponsors here will have just what you need.
          citric acid works.
            Originally posted by rat_tat View Post
            citric acid works.
            Yes- it works to keep technicians employed when the scale plaques it lifts off machine components then block solenoids and other machine components.
            The only descale event for which citric is appropriate is when boilers and pipework are in a bucket- having been removed from a machine
              Which descaler due you favour Chris?
                G'day CL,
                We use Bomboa activated descaler powder and find it really effective #bangforbuck
                  Good to know. thanks
                    Thanks for the info Chris. I checked the Bombora website and the listing says its a commercial grade cleaner.
                    I guess if the instructions aren't followed closely this might do more harm than good seeing its designated as commercial and not domestic use?
                      .....I guess if the instructions aren't followed closely this might do more harm than good ......
                      Errr ? .. as would be the case with any active descaler . !
                        Yes, you don't need much at all otherwise it strips the lube away from your cam and valve actuator pins.
                        Steve
