Hi All,
I'm doing a rebuild on a Bezzera 99, and after reading all the insulation threads here, it sounds like a good idea.
I visited a refrigeration engineering shop today, and they suggested either:
-Self-Adhesive Armaroll (like a tape) 50mm wide, and about 3mm thick, doing a few wraps around. (About $30)
-or they can order in a sheet of 13mm (1/2inch) Armaflex sheet, fire-rated. 1m x 1.5m, for around $90.
From their catalogue info they couldn't confirm it was "HT" but they were very confident that the fire rating means that its safe beyond 120deg.
They also use it for high-temp, leave-in-place building work.
So before I went ahead, I thought I'd run it up the flagpole here..
Any thoughts,
Or anyone want a piece of sheet?
The Bezzera boiler is 20cm tall and 30cm in circumference.
If I was to cut a sheet into six 50x50cm pieces it might be a good investment at $15/piece.
Fire back at me!
Any thoughts,
Fire back at me!
