New to a Rancilio Silvia and servicing it
  • New to a Rancilio Silvia and servicing it
    hi all...
    New coffee person here as I just picked up a used Silvia from Gumtree pretty cheap...
    as the machine has not been used for a few year from the previous owner, I would think it is going to take a bit of cleaning to get it up and running again properly...
    I did a test run of it before buying, and noted that it did not leak when using the brewing and steam buttons which I assume is a good start; The steam knob was stuck initially, but after pulling it out, and putting it back on, I managed to get it turning easily without further hassle.
    I will be descaling the unit first, before running a back flush and taking the shower screen off to give it a nice clean...
    Will I need to do any other things for it?
    Also, what should I look at changing when I first take the unit apart for cleaning?
    The constant thing I hear about the silvia is the risk of burning up the water unit... How can i avoid this? Simply ensure there are always water in the reservoir?
    One final thing... The work flow I have seen so far suggest steaming milk first before pulling a shot... if I were to make 2 cups at the same time, is there much of a waiting time between the 2 shots, or should i steam, pull, steam then pull again? (silly question, but all the videos I have seen are all for one cup only :P)
    hope I can get many years of enjoyment out of this before I even think about needing to upgrade it or mod it
    thanks
    Once you've finished steaming run the brew switch until water comes out (not just a mix of steam + water), or the hot water switch with steam valve open.
    And if you're going to leave it on for a while, re-tighten the steam valve after its cooled down from steaming temperature.
    Nothing should need to be changed apart from the group gasket.
    Check the for water leaks around the pump.
      Sounds simple enough avoid that accident
      guess it is a good idea to have a spare group gasket laying around just in case?
      How long should I wait for the water to heat up before I can pull a shot? when testing it out just than, I noticed the light went off pretty quick... but I read somewhere that it should take about 30 mins?
        The grouphead + portafilter will take a while to get up to temperature, 30 minutes is a reasonable estimate, running hot water through them will speed things up though.
        After a bit of use you will get a feel for how hot the portafilter will be when everythings up to temperature and can use that as a guide.
          Hey hey y'all
          Welcome.
            Hey Mate... fancy to see you here
