Originally posted by Greg Pullman link=1173864679/15#28 date=1173920628
We should perhaps clarify where the break in question is. I think most including Saambo are picturing the puck snapping in half through a vertical plane, as could happen with a Grindenstein with its thin bar. I *think* Dennis is talking about a horizontal fracture (as Ive noticed with my own LM basket), where half the puck comes out and the other half remains within the basket.
Irrespective of that, as Robusto says it doesnt necessarily matter; Ive not noticed this causing any problems with the LM shots compared to the Rancilio, its just a bit messier.
Spot on Greg - horizontal crack just below the ridge
I also use a LM double basket that I bought with Gregs tamper, and sometimes have the same problem with the puck splitting into two layers. It happens if I havent tamped correctly (Im great at doing a lopsided tamp), break the puck up with a toothpick and retamp. I assume that its because the basket is very deep and I dont always break the puck up enough. The puck has never split when Ive tamped correctly to begin with.
thanks Viviane - gee sometimes I think we are all mad...can picture breaking up a puck with a toothpick ;D Ive been known to spend several minutes making designs in lattes with a toothpick then wonder why the coffee is cold :-[
For the time being though, Im going to stick with my giotto senza cresta bucket - after all, I dont want to copy everything you do!
Two coffees tonight - two bee you tee full pucks. I checked these with my trusty thermal probe and they were just 1degree celsius below the correct temperature of 32degrees celsius (thats 89.6 degrees farenheit) after 4 seconds.
Exponential extrapolation: puck consistency may only be slightly improved if basket is 24carat gold-plated
And the real questions:
*How does it taste?
*Did I enjoy it or was my enjoyment spoiled by me thinking about extraneous things?
I also use occasionally an18g coffeeparts basket. Not much any more- I use boema 14g ones now.
Now that Ive got more consistent results ina ll areas, I realise I was probably using the larger basket to make up for inconsistencies in tamping, dosing and temperature.
Not suggesting anyone else has these problems, but some just might (no, no sarcasm intended).
*How does it taste?
Brett
Coffee tastes fine - dont proclaim to be an expert, so some shots are better than others. Im glad Im still learning - life would be too boring otherwise...guess that also answers the 2nd question.
I use the basket that came with the machine because I figure the manufacturer has a better clue than I do. When Im able to blindfold myself and be able to distinguish which side of the mountain the coffee was grown on, Ill probably design my own basket ;D
*How does it taste?
Brett
I like that! Im an inveterate tinkerer myself. I dont think there are any perfect practitioners- coffee, being hydrophillic and many other long words has a tendency to regularly dup you on your **** so we all stuff up. The only difference is its a little less often and perhaps less spectacularly
