I would like assistance from someone who has access to an espresso machine that can easily vary the brew pressure, and that can accept the 58mm Sunbeam Cafe Series (e.g EM6910) filter baskets. You can use your own portafilter, but it must be compatible with the Sunbeam filter baskets.
Here is the test:
1. Fit any Sunbeam 58mm Cafe Series DUAL-WALL(pressurised) basket to a machine that can vary the brew pressure accurately. Do not put any grinds in the basket at all.
2. Make sure the machine is set for a constant brew pressure after any ramp-up.
3. Start a shot, and wait for the pressure to stabilise.
4. Once the pressure has stabilised, put a container under the portafilter and start collecting the pour, and at the same time, start a timer on a stopwatch.
5. Time how long it takes to gather 60mL.
6. If it is 16 seconds, report the brew pressure. (end of test)
7. If the time is longer than 16 seconds, empty the container, increase the brew pressure, and go to step 2.
8. If the time is shorter than 16 seconds, empty the container, reduce the brew pressure, and go to step 2.
Greg.
Here is the test:
Greg.
