Vst basket
  • rustla
    Originally posted by chokkidog View Post
    According to what? 60 ml is pretty much a double espresso. I don't like watery coffee. ;-) But...each to their own! :-D
    I've just got a naked portafilter and a 22g VST basket and have been experimenting.
    For the 22 gram basket in a naked portafilter, what should I be aiming for in terms of mls and timing?
    Dumb question - should I expect a different volume than if I was to use a single or double spout portafilter?
  • barri
    I don't weigh my coffee........but I do have scales. :-D
    A 7gm VST is probably +/- 1 or 2 gms, when playing by the VST rules?? but what it can actually hold, I don't know.
    I've just had a good play with a VST 7gm after reading this thread and the large thread below this one and I am pleased with the results. I followed my normal routine (VBM Jnr & K3 Touch) of dose and collapse twice, fill to a mound and sweep out with Scott Callaghans dosing tool #27 or #28. This sweep out allows a clearance with the screen. I tamped then weighed the basket with and without the grind and found that I had 16gms of coffee, assuming my scales are correct With my VBM single basket using the same technique I got 14gms. I then pulled a shot and it was way too quick. Tightened the grind and bingo. The pour was good with tiger stripes etc, blonded after about 27 seconds, plenty of crema and it tasted delicious. Call it a ristretto or whatever you like but it was a great coffee. I conclude that this basket has made a difference despite my ageing taste buds. I reckon you could get close to 20gms in a 7gm basket but I doubt you'd be able to lock in your group handle.
  • Barry O'Speedwagon
    Out of interest, JM, how many different machines have you tried the VSTs on?
  • Journeyman
    VST's are, by design, rated at about the size given. Don't dose them to the 'normal' level, dose them to the recommended weight. Works well. Some people get VST's and ignore what is said and dose them like they'd dose other baskets and then complain the VST's are hard to use - they aren't, but some people have problems following recommendations.
    From another member who has spent a LONG time making coffees, stick to a little above the rated VST size and you will discover a better level of flavour.
  • rawill
    I don't normally weigh my coffee either, just did it for fun the other day.
    I fill the basket to about 1mm below the top of the 1st step, leaves lots of room for water to settle on the puck!!!
    Wet sometimes sloppy puck.
    It will probably hold at least 3 times that amount of coffee.
    Robin
    My single filter just sits under a pile of coffee 'stuff', at the back of a big drawer, under the coffee machine.
    It is not a VST x 7 gm, so it probably doses somewhere up to 15 gms??
    The single spout p/f has the blind filter in it permanently..... for the daily backflush.
    My regular filter is a 21 gm Precision.
    Snap chokki
  • chokkidog
    I'll be back in a minute........ in the single: 12.4 gms. ( going by volume...maybe a slightly higher dose than this morning )
  • rawill
    I could play around with it a bit more but I consider a circa 7g dose a waste of good coffee!! ;-D :-D :-D
    Cheers.
    So how many grams of ground beans would you put in a single basket?
    I thought a 7gm basket should be about 7grams or a bit less.
  • rawill
    Originally posted by MrJack View Post
    What do you mean by that?
    I mean a bag of beans last longer when using a 7gm VST basket, compared with when I was using the normal Sunbeam single basket.
    I probably put double the grinds in the Sunbeam than I do with the VST.
  • Pete39
    Originally posted by Yelta View Post
    Sounds like you have things nicely under control Pete.
    Hi Yelta, sounds like it hey? Most of the time I can sort things out pretty quickly if things don't taste right, but just when all seems well, something comes up that catches me off guard!! Current issue is with my roasting and the cold weather - have not used my current roasting setup in winter and am finding I need more heat - work to be done, fun to be had!
    I'm with Chokkidog - I tend to like the slow, drippy pours and usually don't get a single stream until about 10 seconds after the first drops (sometimes quite a bit later if the pour is really slow). Much quicker and I loose the flavors I like.
  • chokkidog
    Originally posted by rawill View Post
    A good question, I guess I thought "immediately", no drips, no other streams, just a single pour straight away.
    But now that you have challenged me, I am thinking that is probably impossible.
    This morning there were about 3 or 4 drips, then a single cone.
    Even at the longest, (without having timed it) I am thinking about a second or two before it becomes a single cone, unless of course I really mess up the grind and tamping, which can happen sometimes if I have old beans.
    Hi Robin,
    I'm a fan of syrupy, drippy pours and am happy if I don't see a single stream until the 6th to
    the 12th second ......... but I don't use such a small filter. But I gave it a go........
    Using the single filter, same coffee, grind setting and tamp the drippy bit lasted 3 seconds. ( standard extraction ).
    When I first started with proper coffee, extraction flow was described to me as " a drip that wants to pour ".
    Cheers.
  • Yelta
    Originally posted by Pete39 View Post
    I find the ridge/ridge-less makes no difference in how hard it is to get the puck out cleanly. For me, it depends on dose. If I'm dosing lower, the puck is sloppier and usually doesn't come out in one hit. I don't worry about what the puck looks like at all. I did for ages and then discovered that for my tastes, coffee and gear combination, the yummiest espressos tend to have wet pucks. But I don't use that info at all. I just adjust dose and grind to get the taste I like. Sometimes, the a higher dose gives a nicer shot so the puck is drier, but I don't look at the puck to see if I'm producing nice shots. I also think (again, for my setup) the ridge makes no difference to taste.
  • Pete39
  • MrJack
    The beans last a LOT LONGER with a 7gm VST basket.
  • Dragunov21
    Originally posted by TampIt View Post
    2) You mentioned the puck being hard to remove. That suggests you have the ridged VST's*. A flick of the wrist is enough to send the puck flying out of any ridgeless VST I have encountered, irrespective of roast / grind / dose / tamp / basket size (I have two complete VST sets and have used a few dozen other ones).
    Just wanted to throw in a vote for "harder to remove (and messier, IME)". I need to give a decent bash to get it free first-time and frequently need a follow-up as it doesn't necessarily knock ou in one piece/layer.
    Dead even extraction, close to a piston-fit tamper, average tamp weight, light polish.
