XMT7100 problem
  • RobVH
    Yeah, probably right. I guess $25 doesn't buy a lot of QC. Cheers, Rob.
  • coffee_machinist
    Suspect dodgy transformer in the controller. It's usually that simple.
  • RobVH
    It's a cheapo Fotek 40amp mounted inside the right hand side of the case where the controller is mounted, as far from the boiler as possible.
  • blend52
    What SSR are you using, and where is it located ?
  • RobVH
    started a topic XMT7100 problem
    XMT7100 problem
    Hi all, I've just PID'ed my machine (Older style Lelit PL042) using an XMT7100 controller. When I switch it on it works perfectly but after a variable amount of time the controller will shut down for no reason I can see. It's mounted externally away from the boiler so I wouldn't think temperature would be an issue (especially given ambient temps in Tassie right now). Am I missing something? or did I just get a dodgy unit? Any suggestions would be very much appreciated!
    Rob
