Remnant coffee on shower screen
  • #16
    The reason for so called "5 cent test " management of the puck dose is so that there is enough room left for the puck to expand inside the filter, with the group handle applied to the group, when it is saturated with water. The ideal volumetric size of the spent puck, is for it to have expanded enough to have "kissed" the shower, therefore resulting in an efficient brew (all other variables being good). That then allows for the most efficient exhaust of pressure and water from the puck at the end of the brew cycle - in machines that have a group valve - whether it be an electrovalve - solenoid - or a mechanical vavle - eg manual E61 type.
    If the puck is underdosed OR the grinds are too fine OR if the beans are stale, the exhaust at the end of the brew cycle doesnt work properly leaving sloppy grinds to stick to the shower....
    Hope that helps.
    • #17
      Thanks everyone. I've completed the 5 cent test and there was a clear imprint so I guess I'm dosing correctly however I believe my problem could be grinding too fine. I always buy 250g so freshness isn't a concern but I think I'll move the grinder plates apart a bit.
      I also notice there is sometimes a bit of water left over on top of the puck before discarding and I suspect this indicates I've ground too finely.
      Being a home barista is a fun and rewarding but there's plenty to it! My next step is to get a shot glass to measure extraction!
      • #18
        Originally posted by gunda View Post
        There are some conflicting views being expressed here by people with higher post counts than me.
        A high post count doesn't indicate any degree of expertise, simply that I or others in a similar position have spent more time posting than others.
        My post was just an opinion, TOK has forgotten more about coffee than I will ever know.
        • #19
          What TOK said was what I have read in my research and it meets the common sense test.
          I don't know what to make of those videos with a clear portafilter as there seems to be a large space above the puck pre-shot, whereas what we are talking about is a 5 cent clearance.
          • #20
            In the videos, the puck does not expand during extraction. I have never seen any evidence that pucks expand during extraction. There is clear evidence that the puck moves up (and sometimes onto the shower screen if the head-space is small enough) when the brew pressure is released. I personally think that "puckology" is a red herring. You don't drink the puck.
            Having said that, I think the "5 cent test" does give a reasonable way of estimating a starting dose for any given machine. Even better is to get a set of 0.1g resolution scales and use your pallet. Save your money on a shot glass and weigh your dose and your shot, use your pallet and work from there. Happy brewing!
            • #21
              Happy to run with what the nice video people reckon, but note that either way it's a moot point because the nett result is the same. The puck moves or expands back onto the shower...
              However, I am afraid I will never agree with those that espouse the idea that you should weigh stuff. The whole process depends on the correct tamped volumetric dose, and that depends on the size of the parti-kills ie the grind setting for the particular type of coffee, with a consistent press or tamp. It doesnmadder what the weight it, what matters is the correct volumetric dose irrespective of grind particle size. And that also varies between the type of group that is fitted to any particular type of machine.
              As always however, people are free to think and do as they please
              • #22
                ........I don't know what to make of those videos with a clear portafilter as there seems to be a large space above the puck pre-shot, whereas what we are talking about is a 5 cent clearance.
                A large space at the top if the puck = an UNDER dose. These result in "sloppy" pucks instead of the nice crisp "biscuit", and always leave sloppy grinds behind on the surface of the shower when you remove the group handle. Rather, get the VOLUMETRIC dose right, and everything falls into place nicely.....
                Everything starts from the volumetric dose.
                Some people think its good to use a smaller dose, and they compensate for the resulting faster rate of pour, by adjusting the grind to a finer setting.
                Suggest you try both ways, for a similar rate of pour. Dont worry about whether you get a sloppy puk or not. Just get the similar rate of pour from both methods.
                Cup the resulting brews, and then make up your own mind as to which modus operandi you prefer for yourself It doesnt get any better than that !
                • #23
                  The point of this thread is what do we find on the shower screen post-shot and what does it tell us about dose. After all, dose is part of the grind-dose-tamp trilogy, and thus is important
                  A wet post-shot puck surely must take up more space than a dry pre-shot puck, even if the increase is small. The water isn't going to simply fill up the air spaces. It must swell to some extent.
                  So some of what we find on the shower screen from a well-dosed shot IMHO are some grounds from swelling and some from the release of pressure. In an underdosed shot TOK suggests you may get more grounds from a more vigorous release of pressure. I guess you'll get a layer of grounds on the screen from an overdosed shot. I think I'm doing ok, and it sounds like the OP is as well.
                  I think that the transparent pf video seems to indicate a significantly under-dosed shot and I still don't know how to interpret it. I think there's a slight increase in volume, but at that level how would you tell? If a correctly dosed shot only expands by the height on a 5 cent piece, the increase in that puck would be too small to see. What you do see is the explosive release in pressure as TOK suggested. Just move along ... nothing to see here.
                  [As a noob, I find it easiest to fine-tune the dose accurately and get repeatability of the dose with scales, and cross-checking the dose by the tamp height. This should be a reasonable proxy for volume if the grind isn't changing too much. I think there's less scope for variation compared to fill - collapse - fill - level approaches, which surely must be a fairly imprecise way of getting a consistent volume.]
                  • #24
                    Originally posted by TOK View Post
                    The "5 cent test " management
                    People, don't forget the alternative to the coin test is the rice test and in my opinion neater. Go into youtube and google it but basically you keep putting long grain rice into a dry basket (and make sure the screen is dry as well otherwise the rice stick to the screen) until you just can't lock the group handle in. Take out a few grains at a time until you can lock your handle without resistance from the rice. Then place your tamper on the basket and note where it finishes. A tamper with lines on the edge eg pullman comes in very handy here. This is the spot your tamper should finish after tamping the coffee. I even put the rice back into the rice container which keeps my wife happy.
                    • #25
                      Have heard of the rice method previously but have never been tempted to try it, guess it would work with any small grain, seems like quite a bit of stuffing around compared with the 5 cent piece test.
                      • #26
                        Give it a go Yelta! You only live once ! Just grab half a cup of grain rice not arborio from the pantry. Takes 5 minutes and there is no wastage of valuable coffee. It's accurate because the rice doesn't crush down like coffee so where the tamper finishes on the bed of rice is exactly where you want the tamper to finish after tamping.
                        • #27
                          I found it odd that arborio rice was not good for this test in an Italian espresso machine, after all, isn't it the ingredient in risotto!?!? But it's too clumpy. You want the thinnest grains you can find to get the finest control.
                          The rice test is a lot less messy than the 5 cent test and easier to add or subtract to fine tune the tamp height. But the 5 cent test is a little more precise IMHO and it's worth doing that as well after the rice test to double check.
                          • #28
                            Blokes you can do it with anything you like including gasp horror......ground coffee. Just make sure the shower is dry.....the machine doesnt even need to be switched on, all you are trying to determine is the height in the filter at which the tamped puck just kisses the shower Or if you wish, where it just misses the shower. It will vary from machine to machine (due to different design and or machining of individual group heads). That will be the height in the filter that you should always try to achieve, remembering that the density of the puck will change from coffee blend to coffee blend, or SO to SO, during the staling process, and by the setting of the grind that you choose. Irrespective of all those variables, you always need to try and achieve that same height (or volume) in your filter when the puck is tamped down, for the espresso principle to work at its best.
                            And that will then show you if you have set the correct grind or not. You then change the grind to suit, not the dosed tamped height of the puck which remains the same. Everything works from the puck back.
                            • #29
                              Yep, that's all we're trying to do. We're not looking to make this overly complex, despite what it might seem.
                              • #30
                                Not too sure about that.
                                The subject has been covered time and again, it's a simple concept, all we're trying to do is get the dose into the ball park, from there on everything is fine tuning.
                                The 5 cent piece test has been around for ages and does the job with the materials at hand, a while back someone suggested rice, at one stage there was even a misunderstanding about whether or not to use cooked or uncooked rice now we're being advised as to the best type of rice to use (don't use arborio) crikey!, seriously, I guess you could use Quinoa, poppy seed, pearl barley, split peas or any other grain that tickles your fancy.
                                As far as the 5 cent test being messy and expensive (wasted coffee) it's neither of these things, spend a few moments reflecting on what your trying to do, if you've reached this stage your pretty darned close anyway, so, grind, tamp or whatever you do, drop the coin on top of the puck, do the test, regardless of the result pull the shot and have a brew while you reflect on the results, if you got the imprint you we're looking for, great, if not make some notes, mental or written and do the test again later making the appropriate adjustments.
                                Once you get the result your seeking that's it, forget about it until you change your machine, basket, seal or whatever, I did the test once on my machine almost 5 years ago and have not had to repeat it.
                                It matters little to me whether you use coffee, rice, or custard, what does concern me is misinformation, i.e. coffee is messy and expensive, seriously, it's neither of these things, it's the substance our snobbery revolves around and is readily available, so, why not use it?
