I've had a few requests now for some photos of my monster Silvia, so here they are for anyone interested!
The story goes that I somehow ended up with a customer's Silvia, and seeing a pile of new boilers on the shelf I thought I'd see what could be done to shoehorn a steam boiler in there. There really isn't enough metal in a Silvia for any self respecting coffee tech to be satisfied with. I must have been bored that week...
The design goal was to give the machine all the functions and temperature control of a dual boiler machine in the much smaller Silvia package.
The list of jobs was as follows:
Add separate steam boiler - this would be two Silvia boilers joined at the base and modified as needed
Add auto fill board
Add hot water spout and solenoid
Add PID to brew boiler
Upgrade steam valve
Add pressure gauges for steam and brew
Add tank weight sensor switch
This is the tiny steam boiler heat exchanger. It pre heats the brew water along with some cold water mixed back in.
The bare chassis with boilers installed. All modifications necessary for putting valves and fittings into the steam boiler are done.
Feed pipe for the brew pressure gauge. This is taken from the plug in the group and is after the solenoid, so shows 0 when the group is not being used.
Pump, auto fill controller, boiler fill solenoid, brew SSR and some steam boiler fittings in.
Making cutouts for new front panel additions.
More pics to follow....
Add auto fill board
Upgrade steam valve
