Hi All,
So i'm in the process of giving my mothers Nemox Fenice a bit of a cleanup and new life, the boiler is in the process of a lovely citric acid bath at the moment and will be re-assembled with nice new seals in the coming days.
The steam wand on this machine is average at best, and has a very frustrating "froth enhancer" tip on it. Wanting to swap the entire steam wand with something else, just need to find one with a 14mm ball head so i can use the existing fittings. Wand itself is 6mm tubing.
Any suggestions on a wand that has a similar mount, which i could retrofit on to replace this rubbish one? Had a spare Gaggia baby wand lying around, but it mounts different so won't work. Probably counts out the Silvia too?
