I have been working on a machine and wanted to fit a low voltage pilot light to the machine as the low voltage ones seem to have more options of size and shape. I wanted to swap out the existing dim button light for a 12V LED strip light as it would fit with the new look of the machine.
The problem i have is switching. Currently the pilot light comes straight off the element terminals so when the element is on the light is on. If I am to change the light to one of a different voltage I would need to have an electronic switch to switch the low voltage light on and off. In my experience (limited) I have only ever seen a SSR that uses a low voltage to switch a higher voltage. Is there one that works the other way?
I don't have a lot of room to instal a dedicated 12v transformer for this light, the brew controls are currently 12V so i already have a 12v supply i just need to be able to control it.
Im sure there are people with a lot more electronics experience who can point me in the right direction
