Some machines have no gauges, some with just steam, some with just pump and others have both steam and pump pressure gauges, are gauges there to make the machine look more impressive, to make us think the machine is more sophisticated than it really is, or do they play an important role in producing a great coffee.
I understand there is a cost involved in adding them and hence thats why you don't see them in the lower priced machines, but in the machines that choose to provide just one gauge, why not make it a pump pressure gauge, isn't the pump more important than the pressure of your steam.
From reading and watching videos, a lot of people use the pump gauge to help problem solve and refine their shots, low pressure could indicate, a course a grind or not tampered hard enough or maybe a pump problem, I wounder if after you have gained some experience and had your machine for awhile, and everything is, as they say, dialed in, do you even look at the gauges.
Did the gauges play a part in your decision making when looking for a machine, and after buying that machine, do you look at the gauges everytime you make a coffee, if you don't have gauges would you like one and which one would you select, steam or pump, maybe it is a mod you can do to the machine at a later time.
Tony
Tony
