Picked up a stainless needle valve which I'd like to plumb in to my Bezzera BZ99s as a bypass flow control valve (to mess about with flowrate).
Had a look under the hood yesterday, and think my best option is to put in a couple of tees, and using short sections of 6mm PTFE tubing.
One of the tees will tie in at the upstream end of the PTFE line between the pump discharge and the solenoid. The other at the pump inlet, at the end of the PTFE line from the OPV bypass.
The existing fittings are 1/8" BSP Serto fittings in nickel plated brass (I think). I've seen similar kind of fittings available online, but not sure about the best kind of fitting for the PTFE tube. The OEM lines have an insert and a captive nut.
Anyone know where I can source some of these (sponsors?), or have used them before in an espresso machine?
