Originally posted by Cats
View Post
I had a similar problem. FYI, the Decent DE1 espresso machine also comes in its own suitcase (a sort of scaled up version of the decent tamper kit). It works well enough to pack & move the whole thing in a few minutes.
The soft solutions I found for tampers et al were always the wrong shape.
I ended up buying ($10, fleamarket) an empty DeWalt case (think briefcase size) with the intention of storing some of my DeWalt drills and impact drivers in it. Then inspiration struck. I build a mini platform for all the stray coffee bits out of a flexible bit of plastic, sprayed about 10% of a can of Soudal expanding foam in the DeWalt case and then placed the platform on top before it set (about a ten minute window). The foam moulded to the underside of the platform. I then did the same thing to the lid (i.e. another flexible plastic layer above the bits), sprayed the expanding foam into the "empty lid" (guessed the amount, about 5% of the can) closed the lid and waited for fifteen minutes until the foam sorted itself out.
End result - all those bits fit perfectly... pity I bought a few more bits later(i.e. a couple of larger milk jugs) so they are still running free.
If I had a spare drawer, I could do the same thing in a drawer. The great thing about that foam (apart from a 10x plus expansion rate) is that I can just pull it out of the bottom of the DeWalt case and cut a few more bits out of it later. That particular expanding foam doesn't seem to stick to anything except itself - oh, and it is structural to a surprising degree.
I hope this helps.
TampIt
