Acaia Lunar or Pearl. Are they worth it?
  • Acaia Lunar or Pearl. Are they worth it?
    Currently looking into a more reliable/accurate pair of scales
    I own the Brewista Smart scale 2 but Find it's consistency sub-par for its $100 price tag. Is it worth the investment into a acaia scale? If so where is the best place to purchase? And should I wait till a certain period of the year for a sale. Don't mind waiting!
    I've had a Lunar for nearly 3 years, hasn't missed a beat. I picked up a Smart Scale 2 on the cheap a that or so ago and had a play with side by side with the Lunar for a week or so before passing it on to a friend. I found it to be very consistent, albeit it was usually 0.1g different to the Lunar (I think it was always 0.1g lower, whether or was higher or lower it was consistent). I found it to be slightly slower response-wise, but the bumpy buttons were easier to hit first go in a morning rush. I tell people the Smart Scale 2 is as good as you'll ever need and much better value than an Acaia, but if you value the user experience and money isn't am issue then the Lunar is more polished.
    If you do get one pick up a silicone micro USB plug (to block the hole), to stop and stray grounds getting in. Should come with one in the box but I think it cost me $1 to get 3 delivered to my door from China.
      What do you want to use them for?
      I’ve got the lunar. Basically, it looks pretty, is quite water resistant and has some smart features. The smart features were marginally useful when I was trying to pressure profile with the Vesuvius, but generally those features are more trouble than they are worth ... the apps are pretty clunky and I don’t think that they’re very friendly to third party developers, so I don’t think we’ll be seeing much improvement. Most espresso machines now seem to have shot timers, so the benefit of that is pretty dubious.
      So ... worth it? Pretty hard to justify in my mind. I mean, it’s a great piece of kit, it looks fantastic and it’s nice not to worry about it getting wet, but you could probably buy two or three good small scales from eBay for less than a quarter of the price and always have a spare or two on hand in case you wet one and screwed it up. If you’re using it in a cafe, different story - the water resistance is probably something that will inevitably save time and money.
        Yeah unfortunately when taring off my pf on my brewista it has been out by almost a couple grams give or take so my shots are inconsistent
          Can you recalibrate it with a calibration weight?
            I'll google it soon and see if I can. If not Ive already sent an email off to alternative brewing about the issue
              What are you using to know it's out?
              If you're a buy once, cry once sort of person the Acaia line up will definitely work. If you want value for every single dollar you'll be best to buy a cheaper one off fleabay.
                I bought a cheap scale off the Bay about 8 years ago (from memory paid about $10) still going strong, check it now and again with a 25 gram weight from a set of gem scales, always spot on, if/when they fail will replace with similar.
                  Unsure if it's out, but weird that I weigh my portafilter every single day and the dry weight of it keeps varying from 446.5 down to 445.8. Which to me for a $100 decent enough scales should be more accurate than this
                    Are you flushing hot water through it prior to weighing? Water can hang about under the basket even after shaking, banging, and drying the basket thoroughly. Quite a bit actually. If you are I suggest removing the basket and drying thoroughly in the portafilter as well. See if that fixes it.
                      Can’t seem to find an Acaia Lunar Scale anywhere. Out of stock at most places
                        Unfortunately that's covid for you. I bought mine on ebay originally and had a discount. It was like $30 or 40 off the original price. Hard to find anything cheaper unless it's 2nd hand
                          https://coffeesnobs.com.au/forum/mar...-pearl-s-scale
                          Java "" phile
                          Toys! I must have new toys!!!
                            I have been using a Soehnle Ultra 2.0 to measure for my Kafatek Monolith and Vesuvious setup without issue - and I have only just found out that these made for purpose scales are available. What benefits do they have? I feel I might have been missing something.....
                              Just a very expensive pair of scales. I had the brewista 2's before this and changed to a lunar. I absolutely love the size, quality and the accuracy of the lunars. They come with a calibration weight, and are just super precise. Customisability is pretty great with modes and what you can do
