cold silvia
  • cold silvia
    help folks - my faithful silvia has gone cold on me - she began to cool down gradually then stopped steaming - pump works fine - checked reset button and its fine - i live in rural qld so no dealer close by - any suggestions re which thermostat is the problem??
    Re: cold silvia
    Hate to say it, but if the reset button is no go, you have almost certainly got yourself a dead element.
    A multimeter will confirm that with an infinite resistance reading. A good element reads ~45ohm.
    If your machine has a one piece boiler/element, I have a bloke down here who can tap a new element into the boiler for you. Alternately, youre up for a new boiler and
      Re: cold silvia
      where do you position the multimeter to test the element?
        Re: cold silvia
        With the machine switched off and unplugged, remove the top and test across the 2 ends of the element- visible at the top of the boiler.
        Good luck
          Re: cold silvia
          That is very unfortunate 69Strat. How old is the Silvia?
            Re: cold silvia
            sorry had to go out for a while - silvia is about 4 years old and used constantly - has been an excellent machine till recently when i noticed that the tempreture was a bit variable (draws one good shot then a poor one)
            does anyone know the cost of a new boiler / element ?? Could I fit it myself or should I take it to a repairer in Brisbane? What do you think?
              Re: cold silvia
              Im guessing that Chris has correctly diagnosed the problem as a burnt out element.
              But you did not mention whether or not the big orange light (BOL) is on when Silvia should be heating up? If the BOL does not come on, then that might point to a thermostat problem, which is much less expensive to fix.
              For a step-by-step troubleshooting guide, take a look at this link: http://www.coffeegeek.com/forums/espresso/machines/312139
              Jim
                Re: cold silvia
                BOL remains off and multimeter indicates that it is an element issue - Many thanks to all - who is the rancilio agent in Brisbane??
                  Re: cold silvia
                  I am very puzzled by this.
                  A Silvia is wired so that the BOL will come on whenever the thermostats are calling for heat. This should happen regardless of the condition, or even the presence, of the heater. The light is on a parallel circuit with the heater. (Take a look at Randys excellent web site for a wiring diagram http://home.surewest.net/frcn/Coffee/silviawire.html)
                  So if the light is not coming on, then there is a thermostat problem. There could also be a heater problem, I suppose, but there is a thermostat problem for sure. You can easily confirm by checking for continuity across both thermostats with the machine unplugged and cold. They should both be closed (i.e. conducting).
                  I would hate to see you invest in a new boiler if the problem ultimately turns out to be the steam thermostat.
                  Jim
                    Re: cold silvia
                    Or lightning could strike in the same place twice and its a dead element AND a blown BOL!
                      Re: cold silvia
                      Ouch! Now that would be unlucky
