Intermittent "snapping" switch sound. Normal?
  • Gavin1
    Re: Intermittent "snapping" switch sound. Normal?
    Yup its quite normal.
    My machine does that as well ezra.
  • ezralimm
    thanks for the replies guys
    Yeah, it is like a ticking noise... it is most frequent when the machine is warming up.
    Sometimes, when im close enough, i can even hear a tick and a spring release sound.
    Prob just a thermostat or something.
    Will call sunbeam anyway just to make sure.
  • alskeiru
    Well my Sunbeam EM6910 makes intermittent ticking noises when its left on, which I assume is some sort of thermostat cutting in and out to keep the machine warm?
  • yeeza
    Is it like the sound of your car in the garage after youve turned it off and everything metal starts shrinking back to form. As in is your machine expanding and contracting under the change of temperature?
  • ezralimm
    just noticed i should have made it a little more clear.
    I am referring to the Sunbeam Cafe Crema EM4800 coffee machine... Not the EM0480 grinder.
    edited: I just noticed, the sound appears intermittently even when switched off. for some time. Then it stops.
  • gregpullman
    Hard to say without hearing it but it sounds a bit like the sort of sound you may get with a bean jumping around the burrs without actually getting pulled in; if it was this (or something come loose in there) the timing would be random but would occur quite frequently, i.e. at least once a second.
  • ezralimm
    No it is not vibrating... what i meant was that i could feel the snap when i put my hand on the case.
    The sound is present after switching the machine one, prior to use.
    After use, even if left standing for awhile, the sound returns.
  • foul-up
    Now i hear this snapping switch like sound coming from the machine after ive turned it on. It occurs at totally random intervals. It sounds like a swich being flicked on. A single sound. "Snap!"... "Snap!"...
    when it happens is the machine
    being used or
    has just been used
    or just turned on
    need more details
    graham
  • Gavin1
    When the machine is heating up, ticking noises are normal in sunbeams.
    Snapping? Vibrating? hmmm
    Was it "snapping" before the coffee explosion incident?
  • ezralimm
    started a topic Intermittent "snapping" switch sound. Normal?
    Hi, i recently got hold of a EM0480 to grind for my EM4800.
    My first few trys were disasters as i ground too fine. Setting 12 on the grinder.
    At one point the portafilter disengaged and coffee spilled out everywhere!
    Any ideas to the possible causes for the sound? Ive felt the case vibrate slightly when the sound is made. Yup, its quite loud.
