Izzo Alex Duetto (Twin Boiler E61 Espresso Machine
  • Izzo Alex Duetto (Twin Boiler E61 Espresso Machine
    Originally posted by davec link=1163234999/15#24 date=1212766344
    Izzo Alex Duetto (Twin Boiler E61 Espresso Machine)
    Cost approx £1400-£1600
    Availability - about a week for first 10 (being built now, I have only one at the moment)
    Availability Australia (dont know, I suppose as soon as a distributor contacts Gruppo Izzo?)
    View image here... http://img528.imageshack.us/my.php?i...ge00002wd2.jpg
    Specifications
    Height-Width - Depth: H420 x W360 x D430 mm
    Weight: 32 kg approx
    Voltage & Power (approx): 220 V-50Hz, 2550W max (1150W in steam off mode)...1450-1500W steam 1000W Brew 100-150W Pump
    Temperature control PID for Brew boiler (to solid state relay)
    Adjustable Pressurestat for Steam Boiler
    Water Tank : 2.4 litres, removable with low water sensor/or mains plumbed (switchable, simply move a lever behind drip tray)
    Twin Boilers 1.8 litre Steam/HW, 0.8 litre dedicated brew boiler (can be switched on off independently)
    Pump Type: Commercial Rotary Pump
    Group Head: 1 (E61 type), (manual lever action)
    2 Filter Handle(s ) for 1 or 2 cups, Internal Diameter 58 mm, removable drip tray, cup warmer
    Construction/Finish: Heavy Gauge Polished Stainless Steel case and internal frame
    Water/Steam Ball joint mounted, not cool touch. Steam Boiler can be switched On/Off independently as required
    Boilers Copper with brass end brew boiler. Heavy gauge Copper steam/HW boiler
    2 Manometer Gauges: Measures Boiler & Brew pressure
    Brew Water Preheat Via Custom designed Heat Exchanger in Steam boiler to prevent overheating of brew water, only operates when steam boiler is switched on
    Comes with all fittings and drain assembly for proper plumbed operation. The Duetto can also be used on a standard (cheap) mains timer, if times operation is desired. The group is a standard E61 group, so easy and cheap to maintain.
    Hope you get them soon in Aus 8-)
    Very classy looking machine there davec..... Welcome to CoffeeSnobs [smiley=thumbsup.gif]
    It might be an optical illusion but from the photo it doesnt appear as though there is much room between the bottom of the PF and the top of the drain tray. I know that some manufacturers utilise a reversible tray-top to allow for the use of tallish mugs or glasses, is that what the "Izzo" does?
    Cheers ,
    Re: Izzo Alex Duetto (Twin Boiler E61 Espresso Mac
    Gday Mal & Davec,
    This machine sounds impressive but unfortunately the link to the photo isnt working. Any chance of putting the picture here so we can all see it?
    Thanks,
    Thomas
      Hmm i saw the original post. Somehow its gone...
        when you click on the link you will find that it brings up "http//" twice, simply delete one of them and it will work
        Ray.
          Fixed ....
          The original post can be viewed here... http://coffeesnobs.com.au/YaBB.pl?num=1163234999/15#24
            Thanks for the welcome.
            Your right about the group to drip tray height, it is a little less on the Duetto, compared to some machines. For comparison, the edge of the group (no portafilter inserted) is exactly 12cm above the drip tray. As I also own an older Izzo Alex MK1 and pretty much always use a Naked Portafilter, I dont think about it. In fact the group is a good 1.5 cm higher than the old MK1 Alex of mine.
            The tray top cant be reversible, because it has runners and stays in place when you remove the drip tray (if you want it too)....although with a 1.8 litre drip tray there would be plenty of room for a reversible tray, or even a tray to stand inside the drip tray as an alternative to using the top one. It was actually designed after careful review of other twin boiler machines to try and build on the good points of those machines and improve areas that could be improved (but they missed the cup tray heh  )
              The same measurement on my Expobar Leva is about 14cm.
