I’ve been using this cabinet as my coffee station for a couple of years. I’ve been thinking of. Inverting one of the top drawers to a knock drawer to do away with the knock tube on the bench (more space for gear then). Just wondered if anyone has done something like this or has suggestions for how? I guess the fact that the drawer is wood I would need to think about how moisture from the steaming puck might be an issue. I’d also need to reinforce the drawer somehow so that I don’t just smash the bottom of the drawer into pieces.
Ideas for building a knock drawer
I think your concern about the moisture is well founded. If it's in a drawer, there's going to be the potential for mould formation.
Using a bench top knock box, the moisture can readily evaporate and the grounds are usually dry after a few hours. I probably wouldn't do the in drawer option unless you could commit to emptying it every day.
- Likes 1
I can see the logic in the idea, as others have commented, used pucks enclosed in a wooden drawer seem to be an ideal environment for mould growth.Originally posted by crazyhakins View PostI’ve been using this cabinet as my coffee station for a couple of years. I’ve been thinking of. Inverting one of the top drawers to a knock drawer to do away with the knock tube on the bench (more space for gear then). Just wondered if anyone has done something like this or has suggestions for how? I guess the fact that the drawer is wood I would need to think about how moisture from the steaming puck might be an issue. I’d also need to reinforce the drawer somehow so that I don’t just smash the bottom of the drawer into pieces.
Emptying daily would probably solve the problem.?
This is the direction I'd go in... Though you wouldn't save much bench space.Originally posted by SanderP View PostCould you recess a knock box into the top of the bench?
Ive not personally done it but I've seen it in some commercial settings, jug rinser on L knock box on R of machine.
I've seen setups where a rectangular cut-out on the bench, with a metal knock bar, sits above a drawer - this way the pucks at least have ventilation through the cut-out. You'd have to line the drawer of course, and mould could still be an issue. You also may not want to go cutting into the bench top as it's likely to be a composite rather than solid wood - so any moisture inside could be very bad news.
One other option to save some space is a metal drawer style knock box sitting under the grinder. You'll still have the same potential issues with ventilation and mould, but at least it's purpose made and can be cleaned more thoroughly.
