Thought I'd share my attempts at taming my HX machine's brew temperature. It’s nothing new, I'm not claiming to have discovered any magic; but thought someone my find it interesting. It’s a bit of a long story; just skip to the pics if you don’t want the details.
It all started when I first bought my first "real" espresso machine (Technika IV profi). I couldn't get any consistency in my espresso; especially pulling multiple shots. Just couldn't work out how much to flush between shots.
So the first thing I did was to install a brewhead thermometer (which I've written about in a previous post). Things were much better; the thermometer allowed me to flush the right amount, shot after shot and wait for the group to recover if required.
So all good then I hear you say... well something bugged me about flushing so much water (for the first shot) every time; and the fact I was always trying to perform a balancing act between the group temp and the HX water temp; just bugged me.
I mean to get 4kgs of 98 degree brass cooled down to 93ish degrees take alot of cooler water; so I ended up with a hotter group and cooler water... hoping the mix was right for 93ish degree water.
The next step I took was to turn the P-stat down. I figured if I could get the group temperature down; I'd need to flush less water; hence keeping the HX water hotter with the view of making the balancing act a little easier. I tried setting it at 0.7, and then up a bit to 1. The group temperature lower (to 96 I think) the balancing act was easier; but steam pressure and warm up time suffered. But the worst effect was the group recovery between shots... it took too long. That said I lived with a P-stat set at 1 for a long while; happyish with the results.
Wishing to improve the recovery time I started looking for a way to increase the P-stat without effecting the group temperature (or maybe even lowering it). It seemed thermosiphon restrictor might be the answer.
Enter the dark arts. Not being an expert, so I contacted a site sponsor store to acquire a restrictor suitable for my machine. I ended up getting sent a tiny piece of brass with a 1.8mm orifice; I installed it and turned the P-state back up. It cool the group alright (to about 90) but made the group recovery take forever; I think it caused the thermosiphon to stall.
Disappointed; I enlarged the orifice from 1.8mm to 2.5mm. This resulted in a hotter group but still not bad (around 98 ); then turned the P-stat back down a bit ( to about 1.1) and the group was at 96 and I was back to where I started but the recovery time had improved ( marginally)
Then one morning; I went to pull a shot and the group was in the mid 94's, perfect. It took me awhile to figure it out. It had been getting hotter in my house but we'd just been living with it. But on this morning it had gotten hot enough for the air conditioner to get turned on. What should have been obvious to me all along was that group is effected by room temp and air flow. That’s why the restrictor business is a dark art; because you can tune it to one environment (like an air-conditioned store) but in my house with summer/winter/AirCon/No AirCon it is just never going to be right.
This lead me to googled "Fan E61 espresso" and found like all good ideas someone had already done it; Howard Smith to be exact. Howard Smith has done a very good job of investigating the effect fanning the group. So I thought I'd have a try.
I bought a $10 W3230 temp controller of ebay, paired it with an old PC fan I had lying around, and old mobile's charger. It works excellently; I can turn my P-stat up to have quick group recovery and keep the group temp down. In fact I can set the group to the temp I want ( within a degree); regardless of P-stat. It’s a 12V fan running off a 9v supply so runs next to silent; it seems you really don’t need a lot of airflow to effect the group temperature. I liked it so much I decided it would become a permeant fixture; so I 3d printed a little box for it to live in.
The only downside is it’s a bit ugly; but I think that’s fixable. I’m planning to use what I've got (because it’s working so well) until it breaks and then look at an Arduino nano with a PWM Fan and a IR contactless temperature sensor. This would pretty it up (less cords) and enable a PID variable speed fan controller.
Checkout the video of it working here (https://youtu.be/8vVexTZHG1o )
