Portafilter handle "loosening"
  • Portafilter handle "loosening"
    Hi all. Just lately when I've inserted my handle and started the pump on my Grimac Mia, when the water hits the head the handle winds back a good inch. As in, I tighten to the usual position and then as extraction starts the handle goes from say the 5.30 oclock position to the 6.30 oclock position, if that makes sense?
    Is it simply a need for a new seal or has anyone experienced this and the cause being different?
    Steve.
    I used to experience this on my previous machine when using a silicon seal rather than a rubber one. The rubber seal provided better grip on the handle..
    How old is the seal? They should be replaced annually . You might want to try a slightly thicker seal next time (or buy a spacer gasket) so the handle locks in at 6.30 to 7.30 position.
    • SanderP
      SanderP commented
      Editing a comment
      I'm with Mal on the silicon gaskets they're great.
      I also don't understand why they are not the default now on new machines.
    • flynnaus
      flynnaus commented
      Editing a comment
      Note that i wasn't arguing against silicon gaskets. Steve asked
      I was simply providing my different experience.
      Dimal commented
      Editing a comment
      My machine was only about 5 years old when I started using the silicon gasket and I can assure you the lugs weren't worn.
      I'm not suggesting that your experience isn't valid Steve and given that, for the most part, all of these items are mass produced by a number of different companies to some range of acceptable tolerances that they try to adhere to. Certain combinations of Group Handles to Group Receivers may result in a rare situation where the accrued tolerances allow for a less than ideal interference fit.
    My Silvia started doing this after about 5 years of use, tried new seal and whatever else I thought may have helped, it finally reached the stage where I had to hold the PF in place by hand for the duration of the shot or it would unwind completely and fall on top of the cup making a hell of a mess.
    It finally occurred to me that wear may well be the problem, on examination the chrome on the PF lugs had indeed worn off as well as a significant amount of brass.
    I solved the problem with the judicious use of a sharp fine flat file, dressed the lugs to reduce the angle of contact, never had a problem after this.
    Obviously its a job that needs to be done with care, checking often during the process, it would be easy to remove too much material and from the wrong place, close examination and a bit of thought about the contact faces is needed before starting work, go slowly.🙂
    • amberale
      amberale commented
      Editing a comment
      I suppose that if you can’t fix it yourself it can be considered as a standard replaceable part like tyres on a car.
      It is the part that takes the most physical stress and friction with metal on metal with every pour.
    You can purchase a new naked portafilter from one of the site sponsors for circa $90
    I'd be wary of the real cheapo units you find online some have weird geometries that don't marry to your group head and will cause accelerated wear.
    • Yelta
      Yelta commented
      Editing a comment
      Morning SP.
      Bearing in mind that if the PF has worn its odds on the group head receiver will have worn as well, dressing the PF lugs to match the GH may well be a better option than a new portafilter.
    • amberale
      amberale commented
      Editing a comment
      I suppose it depends on the metals involved.
      If both chrome or nickle plated brass then yes.
      If the grouphead is SS you should be fine.
      All good tips though.
    Ahh gotcha I didn't think of that but it certainly makes sense now you've said it.
      Yelta could you expand on what you did to fix the worn PF that was loosening please?
      I don't really understand how filing more material from a worn part fixes the problem? I would have thought more material would have to be added to the PF lugs (or a thicker gasket)
      I have the same problem with my old Sunbeam, new silicon gasket, the handle pretty much goes round to 4:30 and when pressurised unwinds completely
        G'day Panda, you will note I said "the judicious use of a sharp fine flat file" if you need it explained I suggest you don't attempt the job, you will probably only compound the problem.
        See if you can find a friendly fitter, what your trying to do is reduce the contact angle, as I said, it needs thinking about.
        I'm not familiar with the Sunbeam setup or whether it would even work, I did the job on a Silvia with a brass PF, it worked a treat.🙂
          Crap photo/diagram but I think he means something like this.
          Both lugs need to be filed equally.
            Thanks, no obvious wear on the portafilter, I think it needs a shim under the screen and seal
            anyone know where I might find these?
            i see these ones made of paper or card, don’t they get wet?
            • level3ninja
              level3ninja commented
              Editing a comment
              pandahill make one out of a cereal box. Trace your group head seal. Start too big and trim down. No they normally don't get (very) wet.
