Crema Pro Knocking Sleeve
  • Crema Pro Knocking Sleeve
    Does anyone have any tips on where I can get hold of a spare knocking sleeve as my current one is about to fall apart!
    I've been through the sponsors websites but can't find any. The only sponsor who had them has been out of stock for weeks.
    Clear poly vinyl (PVC) tubing of the appropriate diameter found in the plumbing department of pretty much any hardware store.
    Java "Cheap and works a treat" phile
    Last edited by Javaphile; 6 June 2022, 08:54 PM. Reason: Corrected the name of the tubing
    Toys! I must have new toys!!!
    • eaglemick
      eaglemick commented
      Editing a comment
      But clear
    Mick...try either the Automotive stores or Clarks rubber. even a pro radiator w/shop.
    Seen rubber exterior corded inside hose available by the length on rolls.
    Measuring the diameter required will help you get there easier.
    Pls Report back your findings.
    PS the sign behind says ????
    "Life can be really testy without a good knocking tube hey" !
      And the problem with it being clear is???
      The tubing cleans up quickly and easily with a simple wipe down and when it gets too beat-up for your tastes it's quickly and easily replaced for only a few cents. Plus it's available immediately.
      Java "Been using it for decades" phile
      • eaglemick
        eaglemick commented
        Editing a comment
        Well clear looks shite obviously
      The problem with those hoses is they're not food safe and can impart nasty flavors to the basket/portafilter.
      Java "Something to think about" phile
        Have you tried Coffeeparts? Here's a link for their replacement tube rubbers.
        https://www.coffeeparts.com.au/catal...0tube%20rubber
        • eaglemick
          eaglemick commented
          Editing a comment
          Yep, they're out of stock
        Does it?
        My current poly tubing sleeve has been in place for at least 2 years and has had easily over a thousand pucks knocked out on it.
        This following pics were taken just minutes ago with 10 triple basket sized pucks having been knocked out and the bin emptied.
        The bar left untouched:
Name:	Knock Bar pre-wipe.jpg
        After a quick back and forth wipe of the bar with a paper towel. The paper towel used to wipe it is the one in the pic:
Name:	Knock Bar wiped.jpg
        A closer up shot of the knock bar:
Name:	Knock Bar after wipe close-up.jpg
        All I see is a few grounds (Before the wipe.) and the underlying stainless steel bar.
        Java "What? There's a sleeve on that bar?!?" phile
        • eaglemick
          eaglemick commented
          Editing a comment
          Actually that looks better than I expected
        • robusto
          robusto commented
          Editing a comment
          Same here. I've used irrigation poly tubing for probably 16 years. My first knock box was from memory an ugly, thin plastic pool chlorine?? bucket which lasted maybe years. A wooden dowel and 3/4 inch irrigation tube.
          The current one I made many years ago from scrap plywood lined with plastic laminate. Again, wooden dowelling with 3/4 inch poly irrigation tubing. Even painted the outside. Classy! ?
