Pullman Puck Problem
Thanks Adventurer, yes, you're right, there's a least a 5c headroom, maybe more. I'll try for maybe a 19 or 20 gram dose and coarser grind. I've some 8-day Indian Elephants ready to go, had a couple this morning and the taste was pretty good.Sweet.
- Likes 1
Robusta suggestion is -Originally posted by robusto View PostI have a new 17-19 gram precision ridgeless Pullman basket.....
But the one consistency is the puck stubbornly refusing to make a clean exit. I'm loading 18 grams.
The puck was soupy on top, dry midway through, and as nearly always, breaking up and needing to be rinsed out rather coming out cleanly.
Appreciate any thoughts.
Add extra volume to the dose, you can then adjust the grind courser a touch as you go.
head height gap ?
5c = 1.35mm
10c = 1.75mm
At a guess I'd reckon your gap will be much more than 2mm or so.
GL report back your findings
- Likes 2
Adventurer, too early to review taste. As I said, too many variables at this stage. I'm only concerned about the mess and having to go to the sink to rinse out the puck remnants instead of a quick hot shower under the group.
Robusta / RR I've had this before and something minor in your 'recipe' as Mal refers to in his 2 posts above.Originally posted by Dimal View PostThink it's more to do with the design of the basket; the sides of the basket barely taper down, if at all and this will allow the puck to apply enough friction to the basket sides to resist 'dropping' out...
If your shots back to back are consistent and tasty well then i'd experiment with small baby step changes one at a time.
How close a match is the tamper to that new basket btw?
And of course you know the drill taste is everything....
- Likes 1
I have just purchased a Pullman 18-22 g and am having the same problems . I was putting 18 g in but now use 21 g and have a solid puck but it needs a little force to knock out .I do believe the coffee is nicer but that could be other factors effecting it
- Likes 2
- Likes 2
Thanks Mal. I'll give that a go. This morning I tried a gram less, 17 instead of 18, and one notch coarser, and got the same 31 grams out in 31 seconds.
Coffee was different, Indian Elephant Hills 7 days old.
Although the puck stayed intact, it did require quite a few knocks to coax it out.
It's as though it clings to the sides of the basket. Dunno.
- Likes 1
Could try grinding just a little bit coarser, maybe upping the finishing weight to 45g or so...
- Likes 1
Sounds like the stuck puck happens regardless of machines. I'm struggling to think of relevant questions other than if you changed the bean roast depth at the same time?
- Likes 1
I have a new 17-19 gram precision ridgeless Pullman basket, and it's too early to evaluate taste quality because there are too many variables, using it in different machines, for different coffee styles etc.
But the one consistency is the puck stubbornly refusing to make a clean exit. I'm loading 18 grams. The last extraction was 31 grams in 30 seconds. The grinds don't touch the screen.
