VST Basket and Grinder
  • ausfitter
    Thanks for the input guys. I think I might just take a chance and buy it and see what happens.
  • coffeemachine
    commented on 's reply
    Ok, thanks Blues1143 so you can purchase your VST/new baskets and tamper, try them on your BDB and the will be ok for your next machine.
  • Blues1143
    Sorry I may have misunderstood - BDB certainly takes all 58 mm baskets (mine currently has a 18 gram VST) but it has proprietary lugs on the portafilter itself.
  • coffeemachine
    Ok then you will be better off waiting till you upgrade then buy new baskets/tamper for your new machine.
  • Blues1143
    Sadly BDB not E61 portafilter
  • coffeemachine
    Just check if the BDB has a 58mm portafilter (I think it does), if it does then the basket will fit your Bezzera E61 (which is 58mm). Other BDB owners will be able to confirm this.
    I have the Pullman basket and Pullman Big Step tamper, they fit nicely. I do also have the Normcore v4 tamper, and that works really well with the Pullman baskets and is a lot cheaper than the Big Step. I can recommend both the Pullman Big Step and Normcore V4 tampers.
    A lot of folks here use VST/IMS baskets and are happy with them. You just want to make sure your tamper fits nice and snug with your basket which ever brand you choose.
  • tompoland
    So long as you have some adjustment room left on your grinder you'll be fine to try a VST basket. Worth a try. I doubt you'll taste more than a subtle difference but it's fun to find out.
  • ausfitter
    Thanks guys. Machine is the BDB and using the standard double basket. I am aware the quality of the Breville baskets are pretty good from the get go, but I have read quite a few people say they have had a noticeable flavour change after going to VST/Pullman/IMS.
    I am also going to be upgrading machines in the near future to a Bezzera, and from what I have read/heard, their baskets are pretty ordinary, so I would end up having to buy something shortly anyway.
  • coffeemachine
    And what basket are you looking at buyinG and what coffee machine do you have?
    I believe your current grinder will be ok. It is a low cost investment for more consistency.
  • tompoland
    It probably won't require a big adjustment. But what's the basket you are currently using?
  • ausfitter
    started a topic VST Basket and Grinder
    Apologies if this thread should be posted elsewhere 😳
    I am looking at changing my basket to a VST but have read that a finer grind is requires to get the benefit of this. My grinder is the Rancilio Rocky, so my question is, will this be an acceptable grinder for the job? I dont particularly feel like dishing out $60 for a basket I cant use lol
    Thank you in advance guys 😊
