Knock Bar Barrel
Knock Bar Barrel
I did this a while back but just had the notion to post it here. Its my knock box solution to limited counter space. I was using a home made box that I made from a wooden recipe box. I just added a piece of wooden dowel across the middle of it. It was fine for a couple of years but one day I had a brainstorm and went with it. My Gaggia/Rocky setup is on the counter above my spring-hinged door that I use to access the trash barrel. So I cut a length of dowel and fastened it across the expanse of the trash compartment, just inside and below the access door. Now I just push the door open and knock the puck directly into the trash.
Tags: None
