ECM Giotto leak?
  • ECM Giotto leak?
    I have been looking for a new machine and harassing a couple of sponsors for advice in the process! Im still making my mind up, but in the meantime a work colleague just acquired a "like new" Giotto, so I paid him visit to set it up and see how it goes. (Good for me as there arent any opportunities to demo a machine where I am)
    After getting things set up according to instructions and letting the unit heat up, we noticed a large volume of water pooling under the unit, and the drips were coming from the power cord entry point. After shutting down and mopping up he tried again with the same result.
    Does anyone have similar experiences and what should be done? I figured this forum would be the best place to get him some advice so here I am! :-/
    thanks in advance
    Daniel
    Re: ECM Giotto leak?
    Daniel,
    Where are you located?
    Many of the site sponsors sell the Giotto and would be able to assist in troubleshooting and repair Im sure.
    Brett.
      Originally posted by 71747B7C707920222C24150 link=1235022451/0#0 date=1235022451
      thanks in advance
      Daniel
      Hi Daniel,
      Its most likely the tank coupling. Check to see that the tank is correctly seated and that the tank o-ring is in good condition. If its not, a couple of turns of teflon tape under the gasket will pack it out until you can replace the o-ring.
      If the tank cradle has been removed and poorly replaced, this can create a poor seal on the coupling- also leading to leaks.
      All of these are very quick and easy fixes.
      Good luck
      2mcm
        I am on the Gold Coast....Just checked Go Barista(I thought they were just a mobile cafe type operation) There is dibella but they are Brisbane.
          Hi Daniel,
          I had What sounds like the same leak with my Giotto when I first got it. Took it back to ECA - it turn out to be coming from where one of the silicon hoses connects to the bottom of the reservoir. A quick and easy fix - they slotted a small piece of smaller hose on to it. Had no problems since.
          Your mate could give Charles from ECA a call (see site sponsor <<<&lt - Im sure hed help him out.
            Originally posted by 695C4B4964792E0 link=1235022451/4#4 date=1235025516
            Hi Daniel,
            Thanks Greg and 2mcm, will pass it on
              I think that ringing the CEO of the company might be just a touch OTT  :-?...Sorta like ringing Rupert Murdoch because there a smudge on the front page of the newspaper  ;D
              In my experience, its most likely one of the issues I mentioned and split hoses are extremely rare. A push or some teflon will most likely solve the problem.
              2mcm
                Hi there
                Take the top off and if the plastic breather tube from the bottom of the tank?? has fallen down from its support you can get a leak if the tank is filled up fully as this height could be higher than the top of the tube.
                This happened to me after i last transported the unit.
                An easy fix to put the tube back into place and an easy first check.
                Mal
                  Originally posted by 144B53454E4549404043434B4748260 link=1235022451/6#6 date=1235026734
                  I think that ringing the CEO of the company might be just a touch OTTHuh...Sorta like ringing Rupert Murdoch because there a smudge on the front page of the newspaperGrin
                  Sorta like ringing Rupert? :-? Last time I rang ECA, Charles answered the phone, he even made me a cuppa when I visited (with a Giotto of course - thanks Charles). I think Rupert has someone to do those things for him ;D ,but I get your drift, Chris. Im sure Charles would put you onto the more appropriate technician (I think it was Dave who quickly got mine going).
                    I used to correspond with the former CEO of my bank until he retired.
                    The new guy doesnt seem to want to know me. :-?
                      Originally posted by 6B66656B090 link=1235022451/7#7 date=1235030934
                      Hi there
                      Mal
                      yep, this is what i would be betting on also.
                      i remember the first time i opened up mine i forgot to put that hose back n its spot, filled up the water tank and the water quickly came pouring back out
