Re: Expobar Minore II - Steamwand Tip Replacement
Cool thanks for that guys, so thats one for clockwise, one for anticlock-wise... Can anyone else confirm?
I dont have a pic TG, its just the standard Minore II setup which I bought about 6 months ago-ish, so whatever comes from the factory is what I have.
I may just get the machine serviced and have them change the wand tip for me. Is there a Expobar Service centre in Brisbane? (or a sponsor I can take my machine to so I can get it serviced?).
If it is tight, wrap a cloth around wand and grab with pliers to avoid scratching.
With another set of pliers you should be able to turn tip.
I have played with a few Minores and am sure the tip comes of clockwise.
Dont squeeze wand or tip to hard with pliers
sponsor at left coffeeroasters.com.au carry parts and have 4 holed tips to suit minore.
Could be tight due to burnt milk build up, if this is the case i would take wand off machine and soak. Then clean with pipe cleaner.
dont soak the wand in jug whilst connected to the machine, you could end up contaminating the boiler.
I put a cool touch wand on my Expobar Leva.
The tip unscrews anti-clockwise.
Do you have a picture of yours?
I need to replace/clean the steamwand tip on my Expobar Minore 2, can anyone confirm for me that the tip itself simply unscrews (anti-clockwise)? Or is it a case of removing the whole steamwand itself?
I have tried a few times to unscrew it but to no avail and as it seemed so tight, I didnt want to force it without confirming it simply unscrews first! If it makes any difference, I believe the steam wand is the cool touch type.
I plan to replace it with a 2-hole steamtip available from Coffee Parts, does anyone know if these tips will fit correctly?
Happy Sipping!
Tags: None
